Any ideas on 1/4 swivel/flex sockets 6 pt
bob15
Northeasten, CT
92integra
Grey pneumatic for swivels gets my vote and the gear wrench flex sockets having serving me well
outdoorsman310
DE
if you are going to use them every day, I would go with snap-on they work much better than others I have tried. my craftsman 10mm worked where the snapon didn't though. usually the so works better.
ChevyEFI
Phoenix, AZ
Get the ones you need.
Be honest with yourself about how much dust the 11mm would really collect.
Skip the 5.5 and 9mm.
Mooniac
Wichita, KS
I've got a set of SK and really like them so far for my hobbyist use on small planes. Got them on ebay <$50 IIRC for 6 or 7 of them on a rack.
D
diplomat 1
This is true but I will be using the rest so the set would probably be the best value snap on set is like 250+ and I don't use it enough to justify that much that's why I'm looking for a better priced set but something that's pretty good
AndrewH
Three Rivers, MI
I have the Gearwrench set and it's great. I'd recommend it as the quality of the set I received was flawless and they haven't let me down yet.
Andrew
shockwave
Marietta,ga
Go with gearwrench they are much better on warranty factor and will probably hold up better I got a 3/8 set for my truck bag and I like them better than my coworkers matco universal chromes
ihateminimumwage
Another vote for GW. All my sockets & wrenches I have from them have held up to heavy shop use, no problem.
jethro29
central delaware
if he is an auto tech,he definitely does not want to skip the 5.5,i see them all the time in dashes when I am doing heater cores,evaporators or blend doors and actuators.the Chrysler 300 I did today had about 28 of the 5.5 mm screws in it.
AndrewV
Fl
Andrew
A fellow Andrew stole my thoughts lol.
But you can go an aditional route that i would. i would suggest just getting a set of sunex universal impacts. This would fix the need for them, and have the ability to use impacts at the same time.
So spend less on the long run.
Edit-
Warrany is just as good. If you get buddy buddy with an indy truck driver, he'll warranty them out.
Or register it on the site, and warranty through there.
Mustang1167
Pittsburgh, PA
I have a set on the astro pneumatic in the link. All the small Allan screws that hold the peices together had to be tighten when I received them or they would have fallen apart. I don't use them too often less then a handful of times. I would go with the Gearwrench if I were you.
mrborohachi
Berdoo Route 66
If you have a Matco truck guy their new import line of universal impact sockets. They are an affordable option. A friend of mine at a Big-O tires has them and he likes them.
Skin
Boston
I have Cman and Snap-On. The Cman bind occasionally and then pop and continue to spin normally. The angles they can articulate and continue to function smoothly at aren't the most impressive but they get the job done. Also the pins have some slop in the joint. I imagine Gearwrench cant be any worse than them, in fact considering Gearwrench socket quality i'd expect them to be substantially better.
Snap-Ons are very nice, probably the nicest chrome universals of anywhere. In my browsing I've seen pretty decent looking used sets show up on ebay from time to time for ~$200. Perhaps worth considering.
If USA made matters I'll also toss a Proto/MAC suggestion in there as well. 5 years ago they changed the design to a nickel plated splined pin. They look very sleek. During a 25% off sale at Zoro tools you could pick up a very extensive 12pc Proto set for about $140.00 shipped.
I'll also say you definitely lose some advantage in height with the cheaper sets.
GW 10mm is 37mm tall
Snap-On/Proto/MAC version is 32mm tall
Probably wont matter for 95% of your tasks but that's part of what a premium product is buying you.
Member BB26 posted pictures of his Proto sets and they look simply excellent with very clean broaching and nice chrome. I also like their larger number stampings.
http://www.garagejournal.com/forum/showpost.php?p=3281906&postcount=3
http://www.garagejournal.com/forum/showpost.php?p=3288533&postcount=14
OP is asking about chrome though. When you need chrome, you really need them. Impact universals come with substantially fatter drive ends and all of them top out at a 30 degree articulation angle.
Fedwrench
Valley of the sun
I would consider NAPA'S Carlyle. They offer a very complete 1/4 inch drive metric set in sizes 5 thru 15mm (with 5.5mm) on a rail for $81.00.
I know that's more than Gearwrench but, warranty would be easier with Carlyle and if you have a commercial account, the price is lower.
On a side note, you want a 5.5mm swivel socket as it's a very common size on newer cars from A/C Actuators, blower motors, to other dash type items.
