Any Imperial on new vehicles?
babylou
To all you professional auto mechanics out there: Sometime this year I will be assembling a road tool kit for a new car purchase. I'm unsure of the car choice. Can I omit Imperial sockets and wrenches or does Ford/Gm still work some in?
neonlazer
Lafayette, LA
If I am thinking correctly. I think you mean getting rid of SAE as newer vehicles all use metric?
Skin
Boston
You'll still find the oddball standard fastener, usually its on trucks. Just about everything under the hood and suspension related is metric though.
sk farmer
nd
even though things are mostly metric i don't think it is unheard of to still find sae fasteners here and there. especially if you work on vehicles that have add on or aftermarket accessories. aftermarket bumpers, winches, plows, tow hitches and tool chests on light trucks and cars often come with sae hardware.
bluebolt
Benton LA
I doubt you'll find any SAE fasteners on a model year 2016 consumer vehicle, foreign or domestic.
Trucks are probably the lone holdout. The rear axles in Ford trucks used 5/16-18 bolts to hold the rear covers on. When I worked on one the metric socket didn't fit quite right had to get the SAE one out.
Deej
Colorado
Many spark plugs are now 14mm, new BMW needs a 14mm thin wall 12 point. But most anything you'll ever see will be metric on a car anymore. Torx fasteners are getting very popular
drink
Confused State
I don't consider myself to be a pro mechanic but I have worked on a lot of stuff. When I assembled a small tool kit to go on the road with I selected mostly metric tools. However, I did include a small selection of SAE tools along with an adjustable wrench to be prepared for a limited amount of SAE fasteners if I encounter them. You never know when you might find a beautiful woman with a broken down bicycle with SAE fasteners that needs help, or something similar. .
ravenlord
I believe it was 1971 was the year that all automotive manufactures smartened up and switched over to metric.
panknuckshovel
Land o Lakes FL
A new car? As in fresh off the lot? Just get a AAA unlimited towing gold card and let the guy doing the warranty work worry about what tools are needed.
redmondjp
Redmond, WA
Not correct. General Motors switched over to metric fasteners on their bodies and interiors in the 1977 model year, but any legacy products still in production at that point (such as 1973-87 pickups and 1973-91 Suburbans) as well as engines and other drivetrain components kept using standard fasteners until the end of their respective production runs.
It gets maddening - I have worked on my neighbor's 1998 Safari van with the 4.3l (6-cylinder version of small-block Chevy engine), and it has both standard and metric fasteners right on the engine. The bolts that hold the spark plug wire holders to the heads are 1/4"-20 (7/16" head), while the bolts holding various brackets on the intake manifold are M6 (10mm head).
I'm not sure when Ford and Mopar switched, but I know that my 1990 F350 has both standard and metric fasteners on it, for the same reasons as mentioned above - anything legacy like the 460 engine in it still has SAE fasteners.
finn
The UP, God's country
The 460 has been out of production for 18 years.
It can't be considered a late model, nor could it for the last 12 years.
Time to let go.
byoungblood
Berryville, VA
Dana axles may still use SAE fasteners. When I work on my TJ, it is the only thing I have to get the SAE stuff out for. My 2007 Mazda 3 and 2012 F150 are all metric.
oldtools
If you buy Asian or European vehicle, you don't have to worry about SAE fasteners.
larry_g
oregon
Time to let go.
You certainly have a different opinion of what a late model is... From 1980 to now fits my definition of late model.
lg
no neat sig line
