After flipping through several pages, I've seen many posts with recommendations and even vendors selling RaceDeck. Is there a substantial difference between the two? Why did you choose one over the other?
If anyone is interested in changing their garage flooring, here's another solution that might help you make your decision.
Why did I go with plastic tiles instead of epoxy or porcelain?
I live in an area where labor is expensive so I wanted a solution to use my time to lower costs and to get away from everyone else
Epoxy: The home installed epoxy is fading and I've read that any future touch up will end in a complete replacement which will add up in the long run. Going with a pro install, because I'm no pro, would also mean that I'd have to clear the garage for a number of days and I don't feel like doing that.
Porcelain: This is my favorite look however I think it looks best in larger spaces which is a luxury that I do not have. Dealerships and museums have it down when they use porcelain
. Same install issues with epoxy so this was not an option for me either.
Ordering/Samples
I called Swisstrax directly one day and had a good conversation with one of the associates. Their answer to my list of questions satisfied my needs so I ended up ordering sample tiles which would be refunded if I made an order in the future. At this point I was debating between Pearl Silver/Grey and Smooth/Regular.
(Please let me know if you don't see an image below this)
Samples arrived, so I enlisted the family to test it out. We liked the middle one which is Pearl Silver in the Regular texture (Ribtrax Pro) so I pulled the trigger.
Install
Super easy! Empty the garage floor, leaf blow everything out, then drop and snap. It took me about an hour to drop and snap all the tiles in place that didn't require cutting. For cutting the edges, get the right tool and save time. I used a Dremmel for ALL of it and do not recommend using one for everything.
Before
After
This post feels a bit wordy so I'll post what it's like to clean up in the next one.
. Epoxy: The home installed epoxy is fading and I've read that any future touch up will end in a complete replacement which will add up in the long run. Going with a pro install, because I'm no pro, would also mean that I'd have to clear the garage for a number of days and I don't feel like doing that.
. Same install issues with epoxy so this was not an option for me either.Ordering/Samples
Install
Before
After
