Pen & Wrench
`After several years I finally got into turning pens. I bought a pretty inexpensive Wilton Mini-lathe several years ago and am finally getting around to using it. I tried turning a larger piece on the lathe and it isn't up to the task but it seems pretty good for turning 3/4 by 3/4 pen blanks. I ended up replacing my tiny drill press so I could drill out the pen blanks better. I have a set of steel turning tools. Are the carbide turning tools worth having? I can see that a better sharpening system may be needed at some point. Right now I touch up my turning tools on a diamond honing block. If I keep this up, is there a better lathe I should consider, or just try to wear out the Wilton? So far I have not made anything terribly fancy, but it looks like these are going to make pretty good Christmas gifts for the family. I'm up to 20 pens made, probably a pretty small number compared to any veteran pen turners on the forum, but I can see where this could be an ongoing activity. This whole thing started with trying to figure out some use for our Eastern Red Cedar trees we have been cutting out of our pasture. Most of the pens in the pic are eastern red cedar, but 2 are black walnut from a tree we cut down at our home.
