Any reason to keep this welder?
zendriver
Indiana
Other than “just because”?
Picked it up at an estate auction to flip, haven’t got around to listing it. Thought I try it yesterday on some thin scrap metal, my first stick welding in 40 years.
Puts a bead down that’s about it. Looked like ****, likely my lack of skills. I already have a MiG unit that will go to 3/8”
Steve_P
Sell it like Kay said. I have a Miller stick welder that I never use because I have a Lincoln MIG that does everything I need, and more. The only reason that I haven't sold the Miller is that it was my dad's, but it's getting to that point where I need that extra tiny bit of space on that wall.
Steve_P
Read the specs in the picture; this is a tiny machine. WTF good is a 50A stick welder to 99% of the population? A cheap MIG will do what this does. Yeah, I know, the "I'm ignoring that this runs on electricity, but you can't weld outside in 30 MPH winds with a MIG...." will now chime in and tell us how useful this is. :rolleyes: Fine, buy it from him.
finn
The UP, God's country
Someone will jump in and say “ that’s a name brand welder that will last you a lifetime”.
Just give it to Habitat. Some poor soul will buy it and then question why hid welds have no penetration.
I would personally have a guilty conscience taking some poor soul’s money for it.
dr_clyde
Holland, MI
If it’s low enough amps you can use it for a power source for stainless electropassivation.
For actual welding? Pass.
Its not hard to find a much better stick machine that is cheap, readily available and much larger capacity.
tyyost
Tunkhannock, PA
I had a similar welder that was my grandfathers and was labeled Sears. 50 Amp stick welders cant do much if anything well, so I’d send it along as well. Honestly, the only use I would imagine it would have would have been for an artist/sculptor in the days before affordable mig welders.
dr_clyde
Holland, MI
This machine will not do spot welding, nor can you spot weld with a mig welder.
Spot welding is done via resistance, not an arc. Spot welders are specifically made for just spot welding and can’t do other welding processes. Spot welders are essentially large transformers with pressure tongs to put on the work.
You can make small tacks and make something that kinda looks like a spot weld, but spot welds are not the same as tiny mig welds.
whateg01
doo dah, kansas, usa
Don't tell all the people who have used stick welders as a power supply for a set of tongs and spot welded stuff together with them.
You'll never guess what a stick welder uses to convert the high(ish) voltage and low(ish) current to low voltage and high current (not including inverter machines, even though they still typically have a transformer in them.
dr_clyde
Holland, MI
Bruh, I get that a stick welder is a transformer.
What it doesn’t have is a system for clamping and energizing spot welding tongs, which is arguably what makes a spot welder, a spot welder. The power supply is only one part of it.
