I am most likely getting ready to rent an Edco floor grinder w/ diamond cutters. I degreased the floor yesterday. Originally I was going to acid etch and then grind to smooth it out. I had a couple of bad patch jobs.
After doing a little bit of reading, it sounds like I can skip the acid and just grind the floor. Anything I should look out for before grinding. I will get the safety gear, but don't want to end up taking off too much concrete or screwing it up somehow.
Thanks
Ryan
Thanks
Ryan
