freudianfloyd
Do any of you have experience with the Bahco Easy Cut M42 Band saw Blades? Here is the description:
The 3857 Easy-Cut 3/4 inch blade from Bahco (A Snap-On Industrial Brand) is a bi-metal bandsaw blade engineered to cut a variety of sizes and types of materials. Just one blade does it all, eliminating the headache of changing blades and lost production time in your facility. BAHCO Easy-Cut M42 Bi-metal Bandsaw Blades are designed exclusively for general purpose sawing in tool rooms, machine shops, maintenance rooms, fabricating shops and welding shops. We offer the lowest cost bi-metal multipurpose blade available today.
Easy-Cut blades cut almost anything without changing blades: Tool Steel, Wood, Pipe, Mild Steel, Plastic, Channel, Stainless Steel, Sheet Metal, Angle Iron, Aluminum Tubing, I Beams, Copper, Solids H Beams, Brass, Bundles & Drill Rods.
The unique patented tooth design cuts any shape or size in virtually any material, while eliminating the need to specify pitch or tooth form.
Easy to use - patented anti-tooth-stripping design and M-42 tooth tips combine to create a blade that lasts longer and will not strip teeth like other blades, allowing the operator to spend more time cutting and less time changing saw blades.
They sound almost too good to be true, so they probably are but.....
