Roberts210
I restored an old Famco, ship's wheel arbor press, with a 28" ram, and I need to broach a 1/4" keyway in a pulley. Anybody done this before?
Using thinner shims limits the number of teeth engaged with the work, which limits the force required. The force required is determined by the number of teeth engaged. By using thinner shims, fewer teeth are engaged, even though the depth of cut per tooth is the same.
Thus, you can limit the number of teeth cutting on the stroke to say, two out of ten, which will require much less force. The work is now done by the last few teeth on the broach, and the preceding teeth do no work.
