Saw this on Cool Tools and looked them up. I suppose if you have a very destructive dog or like running over your hose over and over again this seems a bit excessive. Seems way overkill for most home owners, but maybe a good investment for commercial applications. Probably the toughest hose out there, but still $3.54/ft. The 100' is $338.
http://www.armadillohoseproducts.com/pv/DURA-Hose-50-Foot-Hose/3196
The Armadillo Dura Hose is ideal for use within the Construction, Agriculture & Farming industries. This product is impervious to damage from construction debris such as falling bricks or metal or a variety of other objects that cause leaks and damage to standard water hoses. The Armadillo Dura Hose can absorb blows and abrasions from standard farming tools that would otherwise cause impact leaks in standard rubber hoses. Nickel-plated, crush-proof couplings and reinforced nylon-grade tubing provides a fresh water hose that distributes clean odorless and tasteless water. The Armadillo's superior durability also provides resilience to debris, fire, sharp edges and objects, as well as destructive animals. This product functions well with livestock. Ideal for use within Construction & Agriculture Industries
~ Built Tough for Industrial Applications
~ Shell Constructed of Heavy Duty Galvanized Steel
~ Prevents Knotting & Tangling
~ Kink-Free Design
~ Corrosion/Fire/Debris Resistant
~ Drink Safe Non-Toxic Hose
~ Temp Guard (Safe to handle 30-130 F)
~ 150 PSI Durability Rating
~ Residue Free
~ Compatible with all 5/8" water fixtures
~ Crush Proof Nickel Coated Couplings
~ All Weather Grips
~ Kink-Free Design
~ Residue Free
~ All Weather Grips
