anybody uses Sure Shot Sprayer?
t100
if so, what you put in there?
our shop has 2, one is filled with cutting fluid, using as a regular oiler. another one is filled with WD40, it's set to spary the mist for cleaning, lube parts.
I just got one, I'm wondering if I can put in some sort of liquid brake clean or Simple Green and use it to clean stuff.
jwitt
Pensacola, FL
I've used brake clean & Greased Lightning. When I was a Torpedoman in the Navy we used alcohol in them to clean engine parts.
Jim
Stephenw
Utah
I use mine for brake cleaner which I buy in gallon jugs. I have also used it to spray laquer thinner for cleaning a paint gun.
Fedwrench
Valley of the sun
I have several filled with Brake clean at work. Cuts trash way down when filling from a five gallon container instead of using those 15 ounce aersol cans.
I think you can put almost anything in it that won't damage the tank.
ElasDray
Idaho
I fill mine at work with simple green to soak down golf cart tires when checking for air leaks. The high pressure of the Sure Shot is so much better than a pump sprayer.
