anyone blue their tools?
redline380
st. cloud, minnesota
ive bought a few 1/2 socket bits off the mac man. a 14 and 17mm allen head and a polydrive headbolt tool for my car. unfortunately, the bit part started to rust and it bothered me. told the mac guy today they need to find a better way to finish the steel. he told me to blue them so i did when i got home. turned out pretty decent, but we will see how long the rust holds off. i dont have before pics, but i do have an after. for the record i did 4 coats of blue with steel wool polish after each
R
redline380
The bits actually had no finish to them. They were just mild steel. I was going to put oil on them but I liked this idea better. Plus I already had a 20 dollar gun blueing kit at home. I just followed the directions on that. Turned out nice. But like I said we will see how long it lasts
braol
Manchester, Tn
If you dont keep oil on the bits they will still rust. Blueing doesnt protect the metal, it just allows it to hold on to oil better than plain metal.
Justin1776
SW Florida
I have a Craftsman bit socket that I am pretty sure is blued. It has a purple tint to it, I don't remember exactly how I acquired it, it was either 97 cents or I got it in a lot at a pawn shop. Either way, it looks new so I think it came like that from the factory :dunno:
AL`
Texas
How do you do this?
And do you have to remove the black oxide finish first? If so, how did you do that?
There are several methods and kits for bluing. It can be done with cold methods using products such as Brownell's oxphoblue or Birchwood Casey's bluing kits. You can check out either Brownell's or MidwayUSA for bluing kits and products. Gunsmiths usually use a hot bluing technique using hot salts and tanks. Cold bluing is often used for small parts or touchups around items like ironsights etc. There is an older slow rust bluing technique which involves high humidity and salts. This is the type typically found on shotguns since barrel solder can't take the heat of hot nitre bluing.
But for a layman's way of performing hot nitre bluing (which is arguably the best method for tools anyways), check out this article by Marshall Stanton over at Beartoothbullets where he uses stump remover to blue some parts on a Marlin Trapper Carbine project. Pretty nifty and informative for a simple and inexpensive means of hot nitre bluing.
Note: If you don't want to read the entire article, skip down to where you see the stump remover pics and start reading there. Actually, in the previous part on plumb browning, he also details that you need to clean and degrease the parts too.
http://beartoothbullets.com/tech_notes/archive_tech_notes.htm/58
You can also do a search on youtube for bluing and see lots of videos on the subject.
For instance, here is a MidwayUSA video by Larry Potterfield, founder of MidwayUSA illustrating the nitre blueing technique.
