Hephaestus29
I was thinking this might be a fairly easy way to build a tool box ??
At least the framework anyway.
Any thoughts ??
Any thoughts ??
Not a bad idea, I'd like to see the thread when and if you do it. It does seem like there will be a lot of wasted space internally.I was thinking this might be a fairly easy way to build a tool box ??
Any thoughts ??
Well I was thinking of making a Top Box and you really only need 12 pieces for the framework. Then add drawers just made with sheet, drawer slides, and some skin and you're pretty much there.Not a bad idea, I'd like to see the thread when and if you do it. It does seem like there will be a lot of wasted space internally.
What the hell is "80/20"?
8020 has its uses but it's way more expensive than you think.
I've used literally ten's of thousands of feet of aluminum extrusions - 80/20, Item, Bosch, etc. It's great when used in the proper application - building a tool box is not one that comes to mind. You can buy a great tool box for much less than the costs and labor that would be consumed building one from extrusion and sheet metal.
Ha, theres got to be some sort of 80/20 discovery curve.
