Anyone else like Channellocks?
Two Speed
Ontario Canada
^^^^ I have a pair and they do cut flush. Great for cutting zip ties which is what I use them for the most.
Likewise! :thumbup:
Thanks for the confirmation. I'll be adding a pair to the tool box soon.
[edit: I will give these a thumbs up, been using them since, great for trimming tywraps the proper way--and by that I mean no tails waiting to rip you open.]
Alex.
Job
The Rust Belt
I have owned Channelocks for many years, but they definitively went down hill when they decided to rivet their pliers rather than retaining the adjustable nut. That was in '72 as I recall.
The use of rivets in pliers and scissors has always confused me, though I suppose rivets could be replaced with nuts and bolts, when they inevitably wear. More recently (within the past 10-20 years?), Channellocks have changed their rivets from flush to protruding for at least some of their line (#358 here). Or maybe the handles were actually formed that way (with some kind of retainer on the side not shown in the photo)?
Old:
New:
... So, yeah. They don't seem to be getting better, except maybe at marketing.
Job
The Rust Belt
I didn't mean to bash Channellock too much in my last post, because their circlip pliers have served me well. In fact, that's my #1 recommendation from their lineup.
davethorik
Norka, Ohio
That's funny, my Knipex 68-01-200 end nippers have a big ol rivet there too. My Knipex side cutters do not. I wonder if that type of rivet is somehow better for end nipping, or if they are just cheaper to produce.
The only channellocks i have with protruding rivet are the tongue & groove and slip joint.
J
Jim C.
I don't have any Channellock tools surprisingly. I am curious to see how they stack up against Knipex and Snap-On.
Well they're two different price points. Knipex (which I have) and snap on (which I do not have) are what I would consider to be high end, high quality tools. Channellocks (which I have several) are very good tools in their respective category/price point. Well made in the USA and affordable in comparison to Knipex and snap on. Channellocks are extremely reliable, durable, and very often my "go to" pliers/cutters. Give them a try. I think you'll be satisfied for the money you spend on them.
Jim C.
(A few of my favorites are the #422, #357, #718 and #436.)
nolan7120
Chicago Burbs
Just picked up a pair of Channellock (# 927) snap ring pliers. They're really nice for about $20. Just used them to rebuild some of my older Craftsman ratchets. On a side note, if rebuilding a 1/4" Craftsman ratchet, don't take out the little ball bearing as it's a major PITA to get back in.
Riverlos
Inland Empire SoCal
I used to own Channel lock till I discover Knipex .. I had 2 Channel locks (426) snap on me at work. I've been plumbing for 9 years and IMHO knipex gator pliers have a death grip once they grab there a bit pricey but well worth it
VintageOkieDriver
Tulsa OK area
I have 5 sizes/types of channel locks - three of the locking pliers. But I most often find myself reaching for the Craftsman locking pliers instead - I have two sizes of those.
cheechi
Triad, NC
for me it comes down to the handle for some tools rather than the business end. For needle nose, depending what you're working on if you have SO and Knipex then CL won't likely impress you. I like the comfort handle Knipex and the CL Code Blue are comparable to them and to the 'journeyman/2000' series Klein, while the 'regular' handle Knipex & CL are similar, and similar to all SO pliers I've used. For other common pliers types, they are more or less the same in how you use them, the differences may come in durability or material/intended use; common example is what are the cutters intended to cut.
Given the choice I will go with Knipex comfort handles over all of the above. Given the price point and availability, I own several CL pliers though. I really wish they'd expand the Code Blue line especially to the more specialty pliers I'm only going to buy one of ever; I'd go with CL for all of that.
PartsGuy27
Pennsylvania
Jim C.
Jim,
I appreciate the feedback and your personal favorites. I think come next paycheck I'll purchase a few pairs and see how I like them.
-Brian
What exactly is the code blue lineup of tools? I'm not familiar with that.
JohnDeere1
Kentucky
They rust so easy and bad so no I don't and they don't feel like high quality to me, I also have them rebranded Mac and are no better but do have a coating on them but scratch easy.
yamaha0343
South Louisiana
I figure this is probably the best thread for this,
Does anyone have the 758 Flush Cut Diagonal Cutters? if you do, are they true flush cut? (cut the tail off a tywrap, any exposed corners left to snag your finger?). Trying to find something that is a true flush cut to replace a well worn out pair of unknown flush cutters I have used for years. Seems most cutters I've recently tried out leave a millimeter or two sitting proud after a cut.
Alex.
I know this is a Channellock thread, but gotta say I've been happy with Klein flush cutters. I did comms installs on marine vessels for a couple years, and they worked out really well. And cheap.
https://www.amazon.com/dp/B000GTMZHG/?tag=atomicindus08-20
kythri
Lebanon, OR
Admittedly, pretty much the latter - however, I think the V-Jaw will work better for the instances that I've had need to use the 460/480 in my collection. We'll see, next time I'm having to play with a pump or piping. :)
J
Jim C.
I'm a big fan of the V jaws. The #422 is probably the one I use the most and on bigger stuff, like the valve fittings on the in ground sprinkler system, I like the #442.
tym
I do like their oil filter / PVC pipe wrenches. Clever design and very handy in certain situations.
Two Speed
Ontario Canada
I've got a bunch of those, Xcellite branded, work great as you say. I just needed something a bit more heavy duty this time around since I'm cutting larger wire as well, and knowing me, for my current work load I'd have either snapped a tip off or bent them trying to quickly snip through something I should not.
Alex.
Bacon Man
Was able to pick up two Channellock #480 pliers today at a Christian surplus store for $18 all together. Nearly dove across the store to get them.
Dennis Leigh Henry
South Central, IN USA
Hadn't been on this thread is a few weeks (months?) and just caught up. I had an older (Code Blue?) set of small model #30 diagonal cutters break over the weekend. My son was using them as we were rewiring my sister's place. I contacted CL and they're going to replace them with the E41S Little Champ equivalent... So I'm happy in the long run. The #30 were produced in Germany.. and came from my Uncle's estate over 10 years ago, so might have predated the Code Blue brand....
View media item 73431
48548
Phoenix
Just got this today...
48548
Phoenix
here are most of mine....
Dennis Leigh Henry
Those hose clamp pliers are very interesting.. Function as regular pliers when not being used for hose clamps.. Most "regular" hose clamp pliers I've seen don't do that.. they're smooth and can only be used with hose clamps. I also see the hose clamp notches in the "side" of the plier. Some good thought and engineering went into those...
