Jarhead0408
I bought the $99 special at HD yesterday and tried them out after work. Yes I fully charged all 3 batteries.
Before even using them on anything I just played around and pulled the trigger on both. To me at least they both seemed really underpowered. They actually sound like my DeWalts in their last 30 minutes of battery life.
However, I went out last night to the shop to see how powerful they really were. The driver/drill seemed slow when drilling in a 4x4 block of wood on the 1st power setting. On the 2nd it did much better, but still seemed to be reluctant. I haven't tried a paddle-bit or driving screws yet. I'm assuming it'll drive a screw just fine though.
The little impact got tried next. I was already figuring on disappointment based on the performance of the driver. Much to my surprise, the impact works pretty well. While I don't have torque specs available, I used the impact with a 1/2" drive adapter to drive loose the wheel studs on my JD F725 mower as well as to loosen the top frame bolts on my 20-ton press. Just for giggles I had tried to loosen the bolts on the press with a wrench initially, and they didn't budge. I also went to the other wheel on the JD and used a long handled ratchet and extension and tried to take the studs out. They loosened up, but it took a grunt to do it.
Overall I feel as if the driver is underpowered, but would be great for the wife to use inside. I could probably use it outside in the shop for spinning out various screws under the hood too.
The impact on the other hand seems to me to be the more useful of the two. I can easily see using it with a socket adapter to work on my Honda's engine, or for spinning out oil/transmission pan bolts. But I do wonder if just getting the M12 ratchet might not be better?
Another member posted this set up here, I'm thinking about returning the $99 set and getting this instead, and later picking up the M12 ratchet.
http://www.ebay.com/itm/331396399546?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
What do ya'll think? Is the M12 set underpowered for your needs? What will you be using the M12 set for? What do you think about the other set? Who would return this set?
