Anyone Ever get good at using one of these?
zendriver
Indiana
I’ve been trenching for drain tile and electrical, so I’m glad I was able to grab this old school tool at an estate auction. I have seen them in the past paying no attention to them.
Found It’s proper name “crumb shovel”. It has a sturdy 6’ wood handle and is used to smooth and the base and clean loose dirt “crumbs” out of a dirt tile trench.
Round clay or cement tile sections had to have a smooth level surface, in order to **** up tightly against adjoining tiles - without any kind of sealant. If dirt started seeping in, eventually there would be a large crater in the field, requiring it to be dug out. A large farm field might have thousands of tiles, so a good installation was important.
I just goofed with it a bit It did a super job of scooping out the crumbs that keep falling in the electrical trench, I’m waiting for my electrician.
Bert_
NW Iowa
Never had a real one like that. Still just have a sand shovel with the sides bent up and the handle bent about 90°.
Z
zendriver
Indiana
Does anyone still make one? The closest I can find is something called a "bottom digging shovel."
I don’t think I’ve ever seen a newer model of one.
Around here, they only used clay tiles up in to the 1960s or so and even them and I think they had mechanize ways of installing them. Old-school Farm tile was dug around farms all by hand. So this thing had to be a wonder.
I’ve actually been using it today And it works great,so I could see how and This would be must have it in the farmers tool collection.
Normally if I do see one they are in pretty sad shape rusted out with rotted out handles. I was lucky to find one in this nicer shape.
ttpete
Dearborn, MI
Back in the 1950s, there was a guy living in the thumb area of MI who designed and built a tiling machine. It dug the trenches, dropped in the tile and covered them up. This was an area that grew a lot of sugar beets. He made a lot of money doing tiling. We used to go to his place on opening day when there were still pheasant around and hunt his land.
Jbullfrog
Avoca, Iowa
I have a few. I have a 6" wide trench fang for my compact excavator that is 4' tall. I use it for tile and sewer installs and repair. This is the only thing that will reach the bottom to remove clods that have fallen in.
pb57
Sioux City Iowa
I have used them plenty of times when cleaning the trench out of footings. the scoop is adjustable to make it comfortable for varying heights. A lot of work but the easiest way to clean a deep trench (4 or 5 foot) Paul
Bert_
NW Iowa
So I had a chance to use one like the picture this spring. I got to say I was impressed. This is now something I need.
Problem is doing some searching I can't find anyone making this style. I may end up having to build one.
Davefr
OR
That's really cool. There are many times a tool like this would come in handy. The closest I've seen is an Oshkosh spoon and they're not cheap.
Bert_
NW Iowa
I've had crumb shovels that you had to push, like a sand shovel with a steeper angel. This kind let's you pull the shovel along the bottom of the trench. It so much easier, more so the deeper the trench is. I can't believe it's not a popular thing.
I think one can be made pretty easy. I can get a piece of 5" galvanized pipe no problem. Cut part of the top off and weld a couple tabs to attach the handle. Haven't decided what to use for the handle yet. Wood would be nice but not sure about finding one long enough. A piece of 1 in thin wall conduit might work good.
laser3kw
northen IL
I spend a summer on a similar shovel. We called it a "spoon" and used it to clean out man hole pits for run off water.
bugnut
Central Ohio
Buddy buys them at farm auctions, couple bucks at most. He has fond memories of using them on the home farm in his youth.
