anyone ever had any experience with the magic sander?
91bronc300
If it were me, for about the same money I would get this:
http://www.use-enco.com/CGI/INSRIT?PMAKA=505-1370&PMPXNO=953354&PARTPG=INLMK32
$390 from Enco right now and they have free shipping through the end of February, i.e. today with coupon code LVSHIP.
Edit: That may seem expensive but it's USA made and the motor is a Baldor.
H
Hoat
thanks guys I was looking for something that could be used for sanding complex curves in aluminum or other metals and this thing looked neat.
signcrafter
Looks neat but super expensive for what it is. 50 bucks to ship to United State is pretty step I think. I bought a chop saw from Canada a couple years ago and shipping was only like 20-30 bucks and that weighs a lot more than this sander. Unless something changes.
91bronc300
How about a pneumatic belt sander?
I remember somewhere seeing a belt grinder that had no platen behind it and the wheels were spring loaded so that you could push into the belt and the wheels would get pulled together allowing the belt to arc around the work. I can't for life of me remember where I saw it.
signcrafter
Are you looking for stationary or portable? Dynabrade makes a really nice portable belt sander. I think the sander you linked to is nice, just overpriced for what it is and the 50 shipping tab just pushes it over the edge.
neophyte
Pennsylvannia
That type of sander is usually called a "pipe belt sander". They are also manufactured by other companies as well. Most versions tend to be very expensive though. The companies I know of that manufacture the portable version are all German. Fein Tools (maker of the multimaster, the original oscillating tool) manufactures a version called the RS 12-70 E, http://www.feinus.com/en_us/surface...70-e-professional-set-stainless-steel-016117/ This is a video showing the tool in use.
The guy starts to actually use the sander at around the 3:30 mark. The tool is very pricey. Seams to sell for between $1,600 to $2,800. If you check Ebay they do occasionally turn up there. FLEX Tools of Germany makes a version called the LRP 1503 VRA, model # 324.442. Expensive but far less than the Fein at around $700 to $800. These do turn up on Ebay. This is the USA Website, http://www.flexnorthamerica.com/products/LRP1503BOA.php , This is the German website http://www.flex-tools.com/gb/Produkte/Metalloberflachen-Bearbeitung/LRP_1503_VRA/index.php This is a video showing it in use.
Metabo makes a version called the RBE 12-180, these seem to have a street price around $900. http://www.metabo.us/Product-catalog-handheld-powertools.23980+M5c6c6a37ef1.0.html and a video showing that one in use,
Suhner makes two versions, the UTG 9-R, and the UTC 7-R. This is the Suhner brochure with the two sanders and a few others. http://www.suhner-abrasive-expert.c...m/data/free_docs/EN_abrasive_belt_sanders.pdf Lehigh Valley Abrasives carries one of them and it's far less expensive than I would have thought, still expensive though at $770. http://www.lehighvalleyabrasives.com/servlet/the-310/Suhner-UTC-7R-Pipe/Detail
H
Hoat
WOW neophyte that was awesome! so based on you knowledge what do you think of the tool on that website!
250
neophyte
Pennsylvannia
250
The website doesn't list certain information like weight or dimensions. The website also doesn't list the width of the sanding belts it can use. Looking at the construction it probably ways more than the German alternatives., otherwise it does look well made. I'd guess it would at least twice as much or more, if a well established company was producing it. One safety thing I noticed is the drive roller doesn't have a guard on it which seems to be standard on the other tools I linked to. The $50 shipping price is probably about right for Canada. Most shipping costs and/or estimates I gotten to and from Canada tend to be higher than I might have expected, even on small items. If you do buy it I'd probably recommend getting both the bench and angle grinder mounts. It would give you a couple options to use it and if you decided it wasn't for you it would make it easier to sell. I'm actually intrigued by it myself.:drool:
Neohio
Painesville, Ohio
I use 2 electric flex sanders, and one air powered CS Unitec sander. Which is basically the Flex unit with an air motor attached. I use them daily for prepping pipe at work when doing my destructive testing. All I can say is find one that accepts common off the shelf belts. I have to special order my belts online and usually buy 2 or 300 at a time.
