Very weary of Companies offering zero VOC 100% aliphatic polyurea.Correct me if I'm wrong Alpha or Wolverine, but 100% Polyurea is sold to manufacturers and then the manufacturers add their own ingredients to create their own formula and rename it Polyaspartic. From my experience, the higher the solids count the faster it cures and the harder it is to use. So for DIY systems, it has to be thinned out like crazy just to be workable to the average Joe, no? Please educate us.
Not exactly... but close. Yes, there are many companies that do very little of their own formulating with these products. But, what manufacturers are calling a polyaspartic and what manufacturers are calling a polyurea are different. The polyaspartic is technically a type of polyurea that adds a polyaspartic acid ester (diamine) the mix. A polyurea is basically the reaction of the "B" side of a urethane (the isocyanate containing portion) with the "B" side of an epoxy (amine). The polyaspartic is the reaction of an isocyanate with a polyaspartic acid ester containing diamine resin. People use the word polyaspartic to differentiate between a urethane (Polyol + Isocyanate) or a polyurea (Amines that do not contain polyaspartic acid + Isocyanate).
The polyaspartics are a bit difficult to use and make look good. The main benefit is the cure speed and return to service time. You will see many manufacturers saying that they are more durable but that is VERY relative to what they are comparing it to. If you are comparing it to a 'big name brand' epoxy or urethane that has a taber abrasion resistance of only about 50 then it may be more durable. However, if you're comparing against our EnduraShield 2254 than has a Taber abrasion resistance of 9mg then... it's pretty hard to beat that.
The difficulty in application is that the Polyaspartic Acid Ester system is very moisture sensitive. Too much and the stuff is curing on your roller covers... too little and you don't get the same results you want. Now, some manufacturers are trying to add oxizolidine moisture scavengers to even out the cure. We found out early in development that it's a bad idea. It turns out that these moisture scavengers promote yellowing... doh...
Polyaspartic refers to a polyurea that has a slower cure time and is moisture cure (most of the time). It has nothing to do with adding solvents/VOC's or other ingredients and renaming it, it has to do with the chemical reaction. However, there are some polyaspartics that contain maybe 1% or so solvents. Typically, polyurea resin mixes with isocyanate and dries in less than 4 seconds. You probably are already familiar with these types, they are used as spray-on truck bedliners. They are also solvent/VOC free but are not moisture cure.
Both polyureas and polyaspartics can cure in seconds. The cure speed has nothing to do with the definition. Polyaspartics can contain pretty much any concentration of solvents. We've seen formulations from 0% to 73% of solvent... so... 27% to 100% solids. You guys may remember the guy from Florida who posted on here about getting chemical asthma. He was using a 75% solids polyaspartic. His formulation from a big name company skinned on top during application since the moisture in the air made the surface react quickly. The 'skin' trapped the solvent (25% PM Acetate) which leeched out of the coating over time to give him chemical asthma.
While there are polyureas that cure in a few seconds there are also polyureas that are formulated to have long potlifes and cure times as well.
Hopefully Fred/Alphagarage and the Wolverine guy will not lobby to get me kicked off the message board here, but I've been researching for hours a day for the better part of a week and I think I'm ready to pull the trigger on the Rock Solid stuff. $300 a kit covers 250 sqft. I will need 4-5 depending on what I want to do, hopefully I can get a group buy together and save some coin.
Are you kidding me... boy have you got us wrong. When you walk up to us and punch us in the nose for no reason we don't try to get you kicked off the board... we... uhhh... well... we petition the UN to kick you off the planet. But first, we send someone to break your thumbs... then your legs... and... uh... uh... we burn your house down... ummm... and... all your friends' houses get burned down... and.... ummm.... we shoot 'em. lol...
No Fred not directed at you in any way or form, sorry it came across that way. And your right we have never had any dealings, I think the freight would probably eat me up if I were to purchase coatings from y'all. But if it were tax free for Texas then maybe it would wash out.
I was referring to a couple of manufactures up north that like to send spam e-mails to contractors...what a beating. Would never and will never purchase from them.
Awww... Fred can take it... stick it to 'em... lol...
To be honest we have not been pushing Polyaspartic (EnduraShield 4101) at all. The only time we would ever sell it is if we needed an aliphatic clear that absolutely had to be dry in a couple of hours. Otherwise, most applicators have switched to our EnduraShield 2254. Although this is a urethane it is very quick curing for the amount of potlife you get. Plus... it's pretty hard to beat for abrasion resistance. While it should not be applied too thick... that never seems to be a big problem since most people can't afford to put Polyaspartics on thick anyway.
We are probably not going to ever sell Polyaspartic to the DIY market. While I never say never... I will say... the technology would have to improve SIGNIFICANTLY.
But... my advice for the brave DIYer...
1) Make sure you are not allergic since your throat can close up and you can die. This is the best reason to work with a friend. And, while your at it... spend $40 on a good respirator and organic vapor cartridge.
2) Know your humidity, potlife, and temperature.
3) Do NOT use solvent based Polyaspartics.
4) Do NOT use PA that contains oxizolidines (promotes yellowing).
5) Watch your humidity!
6) Have LOTS of roller covers... and... don't cheap out here! Get the best non-shedding roller covers you can.
7) Watch your humidity... and... the dewpoint...
8) Don't drop sweat in the bucket... or cry... or spit...
9) Hire a professional... (threw that in for garageguy... but... seriously... consider this for Polyaspartics!)
10) Watch your humidity...
Been fun hangin' with you guys for awhile... but... gotta run...
