Anyone ever see this before ?
Ace Sprocket
I picked up this Craftsman compressor a while ago, works pretty good. I went to drain the tank and found the petcock had been swapped out for a quick connect fitting. I've never seen anything like this before and can't really figure out why it was done. I had to lift it up onto wood blocks to get enough clearance to get a hose fitting into the coupling so it would drain the water out.
Is there a special tool that would be used to drain the tank this way ?
Right now I'm thinking of getting rid of the coupling and going back to a petcock, unless there's a good reason not to.
Stillgottimefor1
Central texas
probably just something that was added to maybe have a remote drain?
I once had a pc of air hose & a blow gun on it to drain a compressor quickly & easily
That IS a quick-connect fitting. The odds of anything you have fitting it are about one in three . Some person put that there in place of the drain valve. (Same thread size)….could have done it out of necessity, or somebody didn’t want to drain the orange water onto their pretty floor…was the previous owner from new england?
Jinks
Daytona Beach
May have been an old guy like me with a bad back. Bending down to get beneath those tanks to drain them is a pain. Cheap for the manufacturer, but a problem for us old guys. I change 'em out to brass pipe with a ball valve out where I can reach it. Drains the same, & gives any condensation a little space to sit later in a spot that won't rust.
gmcgeo
Anyone ever see anything like this ?
I would put it back to original. I would not want that on mine....
58Yeoman
Central IL
I do a street L fitting at 90* . Then a length of pipe to side of tank . Ball valve . Hose barb and 3ft length of hose to let me drain it in a jug or bucket .
I did the same thing, only I added a length of pvc pipe after the valve/hose that goes out the back wall of the shop, and blows the air/water into the weeds back there.
FMB4
I see nothing odd or funny about it. Like others have said, it makes for an easy way to drain the water off the tank via a hose with a shutoff valve on the end or, better yet, a blowgun (as The Cobbler wisely mentions).
Quote: "That IS a quick-connect fitting". The OP clearly mentions that in his 2nd sentence.
K'ledgeBldr
Johns Creek, GA
The draincocks that came on those compressors were basically a POS. Any accumulation of rust from the tank would usually foul those pretty quick. But, a quick connect in that orientation probably wouldn’t fair any better.
I too, would be doing the street el and a length of pipe w/1/4 turn ball valve.
Pluribus
Skagit County, WA
"Is there a special tool that would be used to drain the tank this way ?" Likely some skids, blocks, or a platform with a hole in it to elevate the tank and easily connect a hose to divert/drain it to where the prior owner wanted.
Here's what I did. Easy-peasy.
brownbagg
i do the same but i added a three foot scrap to the valve handle so I dont have to been over
quickfarms
Southern California
I found one of those on a air tank on a truck and the tank was partially full of a wet oily goo
the tank probably has not been drained in years
A
Ace Sprocket
Thanks for the replies. The way it is now is not convenient at all. I have to lift the whole unit up about 6 inches to get enough clearance.
What exactly is a "Street L" as opposed to any other type of elbow ? (dont really know what "street" means.)
sweetk30
finger lakes area upstate ,ny
someone never pulled the chuck from towing it when broken down ........ or it broke down to much and they just left it in the tank .
but yaa water and oil mix in that tank showed lack of maintenance and a defunct air compressor with lots of blow by .
racecougar
Missouri
MxF
driftpin
90 degrees fitting with M threads on one end, F threads on the other. Ell is short for elbow. Makes it easy to use a length of M NPT threaded pipe to continue from the F tank fixture. Add a 1/4-turn ball valve beyond the vertical wall of the tank, and a length of hose to drain into a container.
LS6 Tommy
Northern NJ
Being as my floor is not pretty & Laying on it to reach an almost inaccessible petcock is no fun, I finagled a top side relief.
5328B928-E647-4962-B594-1C7E5B83F25E.png401137AA-EF1C-4DD2-807F-80FBA8FFC178.png9DEFBB4E-A285-4611-988B-C76F9193A92D.png
I absolutley love the engineering on that! For me, a 1/4" 90° street ell, a 1/4" MNPT x 1/4" compression fitting and some 1/4" soft copper into a 1 gallon washer fluid jug works just fine.
Tommy
FordTruckWench
California
I did the same. Drilled a hole in the tank's foot/support. Routed the pipe through this hole. That way when the compressor is shaking itself to pieces, the extended drain setup isn't torquing just the threads.
I installed the above after I totally destroyed the draincock: "Time to drain the tank, which way do I turn this thing? Oh yeah, the threads are left hand, so I need to turn it backwards. But wait, it opens by turning in, so turn it the other way. OK, it is on the bottom of the tank, i.e. the side opposite from me, so I should turn it the opposite way. Um, I'm bent double, looking at it upside down, so... turn it the other way. And I'm holding pliers "backwards" with the business end off the heal of the hand - so now what?"
