norry
Picked up a Grex 23g recently, used, looked decent. On trying to use it, though, I found that the recoil doesn't seem to work. It fires one pin perfectly, then the driver stays 'down' (extended) until I unload the pins and remove the front of the driver assembly... at which point it will return of its own accord if I tilt the pinner over.
Online advice seems to say that I should check the O-rings. I've had this thing completely apart and the O-rings all look fine, as does the cylinder and the driver. The only part that doesn't look fine was this funny crown-shaped piece of plastic which the factory diagram calls "Cylinder bushing (collar)". That was cracked in 2 places and broken in 1.
I assume that this piece actually does something (though I can't for the life of me figure out exactly what it does), and I'm guessing that it being broken is not good for the tool's function. But before I pay to have one shipped from Grex - if someone here is familiar with the inner workings of these pinners, could you chime in about whether this actually has to do with the problem I'm having? I kinda need to have this working soon, and the guy who sold it to me sounds like he wasn't trying to dump broken merchandise on me (we've been in touch), so if this is a problem unit and I should just buy a newer one, that would also be useful to know.
Thanks in advance!
Thanks in advance!
