Nikon_RH50
- Joined
- Jun 29, 2013
- Messages
- 55
Place socket on the end place opposite end in air hammer place socket over bolt depress trigger on air hammer. The in tense and deep vibrations can loosen bolts and in this case you have control so no heads shear or strip etc. Works on bolts or screws as long as the material is thick enough.
Cypher
I hate to do this, but if this is the case, why is it called the "bolt breaker" and not the "nut breaker?"![]()
I still can't picture how this works. If the bolt if totally stationary, won't the air hammer just bounce back in your hands? And the socket is AROUND the nut, so the nut is not even being touched. There's just a lot of noise surrounding the nut. What would this do??
Like without this tool, if you simulated it by hand, it seems like you're just putting the socket onto the bolt, then removing it, then putting it onto the bolt, then removing it...That would do absolutely nothing to get it loose. Totally confused.
It says right on the for bolts
It's the same thing as an impact driver. You squeeze the trigger and use a wrench to turn the shaft loosening the bolt
Is not going to work for nuts unless you have a 3rd hand. I use mine for rotor hold on screws. But 9/10 I just use a air chisel instead for that[/QUOT
Receipe for nuts:
Use flat or lock washers that the split is twisted together, inside socket so that
The hammering (vibrating) tool is not damaging the threaded end.
Moderate twisting right or left with a short handled wrench will get the nut/cap screw loose eventually.
The principal is the same as using a sharpened punch to hammer a nut,
Capscrew into submission without the damage.
Heating,cutting should be last resort.
Obviously this is time consuming and if damage is not an issue,cut.
Send me all your spare British standard whitworth fasteners.
I still don't get it. What exactly is happening when you put a socket over an air hammer. You're trying to HAMMER the socket onto the bolt? But, it's already seated? All the force is missing the bolt entirely. I can't possibly see how this does anything. Are you twisting the socket at the same time it is jackhammering up and down?
But, how does it vibrate? There is only on/off motion, not sideways.
It sounds like putting the socket on, then pulling it off, but a lot of times.
That would do nothing to remove the bolt, even if you did that for 10,000 years.
Try to think more on a microscopic level. Sort of like an ultrasonic cleaner.I still don't get it. What exactly is happening when you put a socket over an air hammer. You're trying to HAMMER the socket onto the bolt? But, it's already seated? All the force is missing the bolt entirely. I can't possibly see how this does anything. Are you twisting the socket at the same time it is jackhammering up and down?
