Relax
I thought I had my mind made up on an HD-9, but the drive-through height is just a touch too close for comfort if I ever wanted to park my minivan under it. On paper, the HD-7W seems to have all the same dimensions as the HD-9, but with higher lifting height, shorter approach ramps, and lower weight capacity. I'm wondering if the 7000 lbs. rating is because of the higher lifting height using the same footprint, or if it's because they use thinner steel compared to the HD-9. Anyone been able to compare the two?
