anyone have experience with this come-a-long?
scottmlew
I've been meaning to pick one up to have handy for when I inevitably need one, and it looks like a decent price. But I don't want to buy a piece of ****. Anyone have experience with this one, or have recommendations? I found one thread on here from back in 2006 with a few suggestions, but I suspect the market has changed since then. Also, I don't need "the best" come-a-long, just something "good enough".
http://www.tooltopia.com/mountain-5134.aspx
jjarrell4
The Ol' Dominion
That looks like the one I have from Tractor Supply, if its more or less the same 4 ton, its a beast, it pulled my 3/4" ton avalanche out of 3' of mud, and didnt break. I paid 70$ and it was USA, if that makes a difference.
J.P.
Oregon
I've owned a few Mountain things, most of which seemed on par with HF or slightly better. I don't know about the rest on here, but cheap come-a-longs drive me crazy. Trouble is, the better one's are pretty spendy. If you're using it on some real light-duty stuff that may not be a bad deal but I've seen some pretty nasty accidents with come-a-longs.
You may be able to find a decent used one somewhere. May sound weird but these are the types of things you can find at a lot of farm auctions. We bought 5 of them at an auction a few years back.
Jared
Victoria B.C
I woundn't buy a cable style comealong, I would only buy the chain stlyle. All the cable style will do is piss you off.
FoMoCoPower
Lombard,IL
Looks identical to the one sold at Menards,it *****,the teeth strip out easily. The HF one is only slightly better,the reel broke on it.
sberry
Brethren, Michigan
I have a couple of the 4 ton wire ones, actually pretty good for the price. I think I got them at HD for 30 or 35. I used to use the 2 tons at 15$ but they get bent easily and there are slight differences in brands, look them over a little and compare. I have chain drive units too but carry one of those on my pickup. A year or 2 ago I had to plow something late at night, a buggered up deal out in BFE. I am usually a careful guy and have coarse sand on the plow truck, didn't replenish the supply. I slid off just enough to make it impossible to get rear wheel out of a ditch, back and forth, shovel, out of sand, finally realize I have the tool and couple chains I can reach a tree. Put truck in N and winch it out. Was glad not to have to walk 3 miles in bitter weather and didn't want to call someone at midnight.
S
scottmlew
Thanks for the feedback, guys. I think I'll hold off on these until I can do a bit more research...this clearly is a tool that I don't want to break during use!
ksfarmboy
The Wheat State
I have a little made in china 1 ton I bought at orschelns. It has done what I needed it to do, but it pisses me off everytime I use it. I have used a Maasdam Pow'r-Pull some and liked it a heck of a lot more. I think some of the smaller models are for sale at HD and Ace Hardware. The catalog is a little hard to find on their website, but it states that their pullers are made in the USA and have a lifetime warranty!
http://www.maasdam.com/
Scout Driver
South Dakota
Bought a 2000# Superwinch (made in USA) at Northern Tool on sale awhile back. Only gave $49.99 for it. Awesome winch. Don't know what you intend to do with the come-along, but maybe consider a small winch.
Scott
larry_g
oregon
I would suggest two things. Make sure that the hub is steel and that the it has two rachet gears on it. I had one of the cheap ones with an aluminum hub and one rachet gear. While lifting a body from a car the hub split and the whole thing jamed up. I couldn't lift or lower. I had to borrow another one to finish the job. I went out and found one with a steel hub and two rachet gears. That one split also. With the steel one I was able to weld the rachet gears onto the hub and I have been using that one now for 20 years.
Cheap tools are not worth it.
lg
no neat sig line
35mastr
Norcal
X2,All I use is the chain style Coffing brand ones. The cable ones just dont cut it.
Danglerb
SoCal
I bought the HF, I think 8 ton, on sale for about $15, no issues but all I have used it for is dragging a couple cars around. As long as you get one rated about 4 times what you think you need, and use some sense while using it, should be fine.
*** Use it like you expect it to break ***
TheGrooveking
An alternate reality in a parallel universe.
Funny - stupid story, time machine back to 1981. I was living at home with my parents and my neighbor, an older Italian gentleman who only had been in the USA for about 15 years.
Well he cuts down this large oak tree in the center of his yard, but leaves the 4' high stump. So the next spring he and his son dig a hole/pit around this stump, going down about 5 feet. They use an axe (same one they used to cut down the tree) to cut a bunch of the roots, but they still can't manage to get this stump to budge.
So he sees my two cable come-alongs hanging in my father's garage, he asks my father to borrow them, my father hands them over to him. Fast forward to later that afternoon, I come walking up the driveway to see this guy with my two come alongs and some chains wrapped around the top of the stump and the cables of the come-alongs going out and around the base of the power/telephone pole in the corner of his yard. He and his son have pipes on the handles of the come-alongs trying to get that stump to break off.
Needless to say within a few minutes I hear a loud cracking sound and the power/telephone pole falls into his yard. Fortunately no one was electrocuted, so ComEd shows up about a 1/2 hour later and tells the guys that he is paying for the pole and and the labor for them to fix everything. This Italian guy goes nuts and starts blaming me and my father because our come-alongs caused the problem and that we should be charged instead of him. ComEd guy tells, nope you broke you buy it. So a few days later the come-alongs are left on our front porch and they are worthless. Those two goons had stressed them to such a point that their frames collapsed against the spool hubs, there by clamping them into a locked position.
I confronted the idiot old man and he told me to *^&$off, so needless to say we no longer spoke and I advised my father to never loan out any of my tools.
TheGrooveking
Sterff
PA
When I get back from school today Ill post pics of my cable puller. It is made in Pa and they are totally rebuildable. I think it also came with at least a 5 year waranty. They make many different sizes but I can't think of the name right now :headscrat
Major Ramifications
River Ridge, Louisiana
Great story, GrooveKing.
I bought some Dayton brand comealongs from Grainger some years ago. They were well-made, and not too expensive. I bought them to replace some chinese ones that were always a pain and had been stressed to death. Whatever you do, don't buy one with a laminated ratchet "gear", get one with a solid gear.
