I have a Genisys Touch. I like it a lot. It can take a few minutes to get it connected.
PRO:
good battery life
Tablet & VCI modual are wireless.
Tablet has wifi capacity and can link to the net for auto connect to identifix. Has pre loaded shotcuts to Alldata, Michal 1, ITAN and others.
Is quite user friendly. Nice big screan, nice big icons. Data displays have multiple veiwing modes, graph, bar, number, LED...ect. you select only a few and isolate to just those items (like viewing all 4 wheel speed sensors for example) data can be recorded and saved. DTCs can be printed directly, emailed or saved in PDF format to a flash drive (awesome way of showing a customer a whole sheet with every DTC on it.) And they are separated by module, Engine, Transmission, ABS, ect.
Con
Startup can take a while. It sometimes has difficulty clearing some codes, it does freeze from time to time, best way to eliminate this is to shut it off at night, not just sleep mode.
it is not as fast as a code reader for just pulling codes, but it does so much more. it can pull codes out of every computer, not just PCM (so abs, airbag, trans, BCM, ect) the VCI wireless module doubles as a J-2534 pass through for flashing PCM's (you need a laptop with the appropriate software to do it properly)
all in all, i my opinion, i would buy it again. It has proven to be a very, very good investment, running a few thousand less then a Verdict or Verus, there are no "keys" to buy, the software updates are less then half of snap on. (and they update 6 or so times a year) the kit comes with just about every OBD-1 connector you will need EXCEPT GM 12 pin, for some ungodly reason they don't include that one. good news is its not much, i think it runs like 50 bucks or so.
