nate379
My thought on a box store unit is if it lasts for 10-15 years, I can replace it 5-6 times to equal the cost of ONE Kinetico unit.
I don't doubt they aren't good units, but not something I can afford.
As far as salt use (someone asked) it all depends on how hard your water is and how much water you use. My Dad says he fills their softener every 4-5 months and it holds 120lbs.
I used to install water softeners awhile back; there are five basic control heads that I know of, Autotrol, Clack, Erie, Fleck and Kinetico. I know other have said they have had good luck with the big box store brands, but most of them have smaller control valves that tend not to hold up as well as the ones you would buy from a dealer or online.
I would recommend one with a Clack or Autotrol valve, they are the easiest ones to work on when (not if) something goes wrong. I currently have a Kinetico only because I was able to buy it at cost when I installed for them. Prior to that I had one with the Autotrol valve that lasted 20 years; with me rebuilding the control valve at about 15 years. As far as I know it still may be in the house, it was there when I sold it.
If I still did not have a local source for softeners I think I would order a Clack online and install it myself. It is not hard to do if you have basic plumbing skills.
Here is a link on how to size a water softener; http://www.qualitywaterassociates.com/softeners/sizingchart.htm
If you google Clack water softeners you will find a number of places you can order them from.
