cw_racefan
- Joined
- Feb 7, 2006
- Messages
- 254
Sort of garage related (I'm working on it in my garage
I have a mini skid steer (stand on variety) and while cleaning up snow, it started puking hydraulic fluid out the breather vent on the tank. I messed with it a little bit, and it appears that something is causing the fluid to foam. Fluid looks clean, doesn't look like there's any water, just foam. The lift cylinder has a bit of a leak, but has had it for over a year with no issues. No idea where to start troubleshooting, since I've never worked on hydraulics before. Changed the filter, topped off the fluid thinking it might be low, and still the same issue. There does appear to be a small drip from the housing between the gear pump and the engine. It's a Kanga G520 skid steer if that's of any help. Not sure where to start looking?
Thanks!
Craig
Thanks!
Craig
