Anyone know what this attachment is?
J
j90st
Tapping head maybe. Too hard to verify that's a tap, on my phone.
I believe you're correct
I did a search after you mentioned tapping head, and similar products showed up
Provincial
Near Salem, OR
The collet with the tap in it is a tip-off.
What does the drive connection in the casting opposite the tap end look like. It appears that the housing bolts onto a machine with a drive spindle.
J
j90st
It's not my drill press. Someone in my town is selling it
Whitworth
Hard to tell for sure, but it looks like a Delta DP220 drill press. They (Delta) indeed did have tapping heads that fasten directly to the quill, made by Procunier.
( Looks like Superman bent the feed handle 90 degrees. )
J
j90st
It is a delta drill press but not sure on the model. I bet superman was the one using it, and possibly got pissed off the handle kept moving
