Anyone Make a Mini Blower?
ItsNemo
Canada
Does anyone make a cordless mini blower? Like think those compressed air duster cans but in a drill sized cordless tool?
I have the cordless leaf blower and have the 60 gallon compressor with lots of blow guns and hose...but it would be nice to have a tiny handheld thing to quickly dust something off.
I
ItsNemo
Canada
Well damn, that would be perfect...but I was hoping not to have to start a new battery line up.
ching0n
I have a leaf blower and a workspace blower that's much lighter w/a flexible pipe. I suppose one could shorten said pipe to make it compact:
I think technically you can turn it into a vacuum by reversing inlet outlet which is the more recommended way of handling shavings on equipment to avoid long term wear on surfaces.
Rabid Badger
Those aren't comparable to the Makita.
The Makita is more akin to an air compressor blow gun than a mini leaf blower. It is awesome.
darkzero
SoCal
Here's mine. It works fine & was cheap but you get what you pay for. I still may get the Makita someday.
I got this long before the Makita LXT (18V) came out or was announced & there was only the XGT (40v Max). This is actually molded from the XGT model.
I still need to make me new labels for it. I'm calling mine the Milkita.
Just a word of caution with those battery adapters. For most, the low voltage cutoff is built in the tool and not the battery like Ryobi. So in my case using an M18 to Makita have to pay attention to battery level cause nothing will prevent the battery from draining too low.
In addition, the ones with a USB port. The USB circuit will cause parasitic drain on the battery so when not in use for long periods of time, remove the battery. Otherwise eventually it will over drain the battery also.
That bugged the hell out of me & the USB port is useless to me. I took care of that by disabling the USB circuit. No more parasitic drain. I put a cover on the USB port also
darkzero
SoCal
Oh by the way M12 blower is not too big, I got one for my brother a couple of yrs ago for Christmas. Comes with a stubby nozzle & it's good for dusting off things & light duty, not nearly powerful enough for yard work. It's not brushless though if that matters to you.
Just_Steve
Dutchess County, NY
Good information, thanks.
ching0n
Just remembered kobalt makes a smaller inflator that doubles as a duster, I may pick that up. Others may make it as well? Specs on Makita?
darkzero
SoCal
Ryobi makes one like that too. Both the Ryobi & Kobalt don't work that well as mini blowers, not as good as the Makita anyway.
klassenl
Southern Alberta
I believe that (nominally) all lithium batteries have built in low voltage protection. Even the little rechargeables in small electronics.
However, there may be other things going on between the battery and the tool that protect both.
I
ItsNemo
Canada
Separate cells yes, but not always the case in packs. You can draw a Dewalt battery down until it's ruined if it weren't for the low voltage cutoff in the tools.
darkzero
SoCal
Nope, not all. What you are referring to are known as protected cells which have a circuit board attached to usually the top of the cell for low voltage cutoff. They are commonly used in devices such as flashlights where the battery is user replaceable. It also adds to the overall length of the cell which cause fitment issues. Bare cells, aka unprotected, are just the cell that is used for building packs & use a seperate means of protection either built in the pack or in the device.
Cordless tools usually have the battery protection built into the tool. The pack does have a battery management circuit for other reasons. Of the major tool brands, I know Ryobi has the protection built into the pack because Ryobi's design is so that their battery packs are compatible with all their generation tools, even their older NiCad tools where you can use a lithium pack. Most others you can definitely drain them down to dangerous levels when used in applications they were not designed/intended to be used in.
klassenl
Southern Alberta
Ok. My Makita batteries have protection in them. I have a battery adapter and when I use it the battery will cut out when it needs charging.
darkzero
SoCal
I don't currently own any Makita so I can't say for sure but from what I have heard, not all Makita batteries have low voltage built into the pack either.
From what I have heard only their Star system packs have low voltage protection in the pack. Their Star system is what they call the communication system between the tool & battery like other tool brands.
KnurledNut
n/a
All Makita batteries have had Star Protection since 2012.
All these have low-voltage cutoff in the pack.
The black chargers also provide cell balancing. The blue chargers will still charge all batteries, but lack this feature.
The original non-star batteries had a cut-off limit but they could still be over-discharged in certain conditions just enough that they wouldnt charge. I’ve jumped several perfectly good batteries in this condition. Dont see too many non-star batteries anymore. Besides being well aged now, people tossed them assuming they were bricked.
reclaimer
The Makita blower has some accessories that I haven't seen with the others. The inflator nozzle for blowing up stuff, and the flexible tube with precision tip are very handy. It also has a couple sized nozzles and one that blows like a fan to clear off a table. It has a replaceable filter depending on how clean you need to air to be, can also **** in reverse, and has 4 speed settings. Good for starting BBQs too!
ching0n
the Makita advertises substantially higher air speed and quite a bit more airflow. I reckon the smaller nozzle size contributes to that air speed (plus added flow) and likely the others measure speed w/the default larger opening. I'd be curious about how this functionally translates given the ryobi you can pick up for 10$ sometimes on that online tool outlet. I can see these cheapo ones being handy to keep around large power tools (drill, mill, lathe, bench saw), though maybe not strong enough to dislodge cobwebs from circuit boards.
bonneyman
Desert SW
I love these "Does anybody have a recommendation?" threads. You guys have such good suggestions and funny jokes!
The power of USB is a hoot! :LOL:
tak1313
Ryobi makes a similar "inflator" for their 18+ line that some use as a blower (P738). It's likely at your nearest HD (the one near me shows 7 in stock). If you already have 18v batteries, the tool only is $35.
Rinspeed
NY
I would have to say that is one tool I have zero interest or use for.
tak1313
FYI on the Ryobi p738.
I was just digging into it a little more, and there seems to be a fairly consistent problem with using the tool with the newer 18+ batteries (the newer black ones).
People are complaining that it would shut down after a few seconds only when using the new batteries (in multiple AH ratings), but works fine with the HD and older generation batteries. I suspect the REAL problem probably lies in the interaction between the blower and the batteries' protection circuits as everyone that reports the problem state that the same batteries work fine with other 18+ tools.
milky2k
Los Angeles CA
I have a Ryobi duster and I thought it was just okay. It has a high pitched whine that makes me want to put on ear protection. I bought it as an alternative to my Makita mini leaf blower. I didn’t know about the Makita duster until I saw this thread and I think I want it. It’s much larger than the Ryobi and hopefully not as high pitched as the Ryobi. However, it’s $200 which makes it very pricey for me. For better or for worse, Amazon has a knock off for $50. There are knockoffs for your favorite battery platform too. Since these appear to be more within my budget does anyone have any experience with these? Maybe the factory making the Makita version is making the knockoffs during the second shift?
Compressed Air Duster Machine for Makita, Cordless Brushless Inflator Cleaner Duster Leaf Blower, for Cleaning dust, Hair,Inflating Swimming Pools and Inflatable beds, Vacuum Compression https://www.amazon.com/dp/B0CD23CPJL/?tag=atomicindus08-20
darkzero
SoCal
Mine posted in this thread has no variable speed & the mode button is a dummy, it doesn't do anything except light up a useles LED. Which is why I said you get what you pay for & I still want to get an orig Makita.
Be sure to research if you buy the teal clone ones, they are not all the same, some the fan fails very commonly.
PelicanPines
Just got this M12 Mini Blower FREE from home depot ... qualifying purchase of a 4ah battery and 2ah battery deal with charger for $149 total
kinggsxr
Northern VA
I have the M18 compact blower and it is nice for use in the garage and porch, but I wish Milwaukee would make one in the form factor as the Makita. I'd buy that in an instant.
