Anyone recognize this compressor pump?
alemmons
I knew when I got this but that was several years ago. Pretty sure it was an Ingersoll Rand pump. I pulled the flywheel off for some reason but I can't remember what model this pump is. The only numbers I can find are shown on the front. Thanks in advance.
MacMcMacmac
canada
It's an ABAC pump, but probably sold under a different manufacturer's name. They were packaged by many different companies into cheaper units. Even Quincy sells compressors with them now. You need the exact model, since two pumps that look identical may be half a bolt hole out in terms of size. We learned that years ago by trying to make one good one out of two bad ones. Congrats on getting that flywheel off in one piece.
redmondjp
Redmond, WA
Take a look at this website and see if you can match it up - I agree that it's an ABAC/American IMC pump, which is made in Italy:
http://www.i90enter.com/
I don't see any exact matches, but they have changed some of the designs over the past 25 years. My 1990 Ingersoll-Rand has this brand of pump on it - most of the parts were NLA by the late 1990s.
Davefr
OR
Unfortunately I do recognize this pump. It looks like the one IR used on their T21 compressor.
It's garbage quality. The reed valves break off and the head gasket blows because the aluminum head doesn't stay tight.
Parts are unobtanium.
