Anyone recognize this lower garage door seal?
jcar302
Hey guys, i need a new garage door seal. There is a tag on my door that says wayne dalton.
Can't find and exact match though.
Before i buy a generic with matching edges and try it, i'd like to see if anyone knows where to get it.
Thanks for any help
Joe
AndyL
Vancouver
Looks like the older style Wayne Dalton 9100/9600 rubber - While possible to replace its usually way easier to replace the retainer too (its a battle, not impossible if the doors out, almost impossible installed). Local dealer here sells it on retainer not otherwise for this reason. About 12 screws/rivets (depending on age) and your done...
upndown
Desert Hills/Peeples Valley AZ.
That looks like the old Foamcore bottom w/s! Good luck finding it, they haven't made that door in years, changed many of those over the years.
It Can be changed with the door installed, easiest with 2 people. Just open the door about 3/4 of the way, pop out the bottom roller, pull out the old w/s.
On either end you'll find the bottom extrusion is dimple crimped, take a drill and open the crimp. Spray some WD-40 in each groove, start to feed in new w/s, one guy feeds the w/s, while the other slowly pulls. Once that's done make sure to crimp at both ends or the w/s will shrink! Put the roller back in and pop back into track..All done. Good luck..:beer:
J
jcar302
Thanks for the responses.
Pattenp, that's the one i thought it was, looks like they altered the design to make it easier.
Kinda pricey isn't it?
Is there a generic cheaper? I don't mind paying but if i'm reading other sites and links right, for a similar price i could get a new track and seal.
