Anyone recognize this water shutoff stem?
stickshift
northeastern US
Need to replace the stem and I bought a universal stem repair kit, but the original stem threads are 0.608" diameter while the universal stem threads are 0.613" in diameter. Won't even go in 1 full turn, so I guess I have to find the exact match. Anyone recognize this particular stem? No name on faucet.
BillK
Beautiful Southern Maryland
Pretty sure Home Depot has a book hanging where the stems are that has pictures and dimensions so you can match your old stem to a replacement. There are so many different types I cant imagine a "universal" one.
Fav Onefour
MN cold and hot
Normally I'd agree with the plumbing shop advice but I'm not sure in this case. The original looks like a lower quality unit. I'm not sure if the plumbing shops would have a direct replacement.
Replacing the washer might get you by for awhile. How is the seat? Those start to corrode - wear with long term leaking. I see marks on the stem that look fairly deep. Replace the compression washer if you want to reuse the stem. I'd tighten the cap in steps to wear in the compression washer.
How hard would it be to replace the whole faucet assembly? I get tired of fixing poorly made faucets and usually just replace them.
nadogail
Coronado, CA
I have developed a strong preference for MOEN brand faucets. They are very easy to install, have clear instructions and excellent customer support.
Moen products are my preferred choice for my home and rentals.
Fav Onefour
MN cold and hot
I'd agree. I have had good luck with them. I quit trying to repair the cheap faucets. I just replace them with good faucets and go on with life.
One item of caution. There are some that appear to be branded but are knock offs. I've run into the issue a couple of times. They look the same but the components are junk. Standard cartridges didn't even fit.
stickshift
northeastern US
The stems in the OP aren't from a faucet, they are from the water shutoff valves on the supply lines. Anyway, Home Depot's catalog (in the plumbing section) is for faucet stems, and since the universal shutoff valve stem didn't fit (I've been lucky with those in the past), I replaced both valves.
jhelrey
MN
Looks like a Temptrol shut off valves. One on either side of the main body.
Two Speed
Ontario Canada
Pry the washer off the original, that one on that plastic replacement is probably the same size, if not, the original washer might have a number on it. If not, easy matter to find a replacement washer.
