Anyone recommend a contractor in MA? (30x40)
0100
Need to have a 30'x40' garage built. I was going to do this myself but with my kid being born last week :thumbup: and work, I have no time. If I did this myself it would be much cheaper but would take me years to finish. :(
Anyway, anyone have any builders they would recommend in the MA (NorthShore) area?
Big thanks!
Elky
Lowell, MA
A friend of mine is a contractor on the north shore.
Give me some more info on what you are looking for and i will see if he has room in his schedule
shocksystems
Ipswich, MA USA
Big thanks!
The person building my garage (20x37) in Ipswich is Jack Desmond. PM me for his phone #. I am very pleased with the work he is doing.
Cheers!
Jim
0100
Awesome Elky and Jim!
You guys rock! I just wrote down Jacks number so you may want to delete it off the net.
I have a cape with a tiny 1 car garage. That will need to be torn down. That should be no problem, it is tiny. I need to cut down a monster tree which I plan on doing very soon.
I want a 30'x40' garage built. I guess you could call it attached but really it won't be. No walls, foundation or anything will be shared with the house. Basicly a 30'x40' detached garage that is 1/2" away from the house. I hope this will make it easier for the builder. After I do the siding it will look attached.
I need to get a variance for 30' wide so it may end up being 24'-30' wide depending on what they will give me. :(
I want 3.5" floor at the front half, and a 5.5" floor at the rear half, with two 8" thick sections where the lift will bolt down(rear half). 3000 PSI concrete.
I want either 12' walls or standard walls with vaulted trusses in the rear half to give room for the lift(12').
1 garage door in the front and 1 man door in the rear.
I want Storage type roof trusses.
The main thing is I don't want poles in the center of the garage to support the trusses.
I can do the outside siding, finish the roof, wiring, lighting, insulation, and inside finishing work.
Any estimates on this project?
You guys rock! :thumbup:
Anyone else on the north shore?
