I see the need for an engineer.
Pole barns are rarely engineered, or required to be. this is a question mainly for guys that have built, or been around a pole barn that has been built similar to what I am building. I know what is required based on other buildings in my area. But I have this question because they were built using 6X6's. Not laminated post's.
My post embedment will be more than enough. Especially considering the concrete slab will be around each post. this building could stand on top of the ground once the metal is on and bracing is done.
None of us know what area that might be...![]()
40'x56'x14'
3 ply 2x6, bought as a "kit" from lumberyard, and passed inspection.
What are you using for your truss carriers (top beam) and how will they be attached to the posts. Best is brackets directly on top. Almost is good, is set into the post.
He is talking about hanging the carriers. Not how the truss is attached to the post. I did both on my building. One side is notched and one side is sitting on a bearing block. The carriers are thru bolted with 1/2" carriage bolts and i didnt want the ends of the bolts sticking through on the inside of the building because im finishing it with metal on the inside.Why would you say a bracket is better than dropping the truss into a 4 ply truss where the outer ply's are used to truss lock into the column? That's bullet proof design.
What he stated, "...just want to see what you guys have done from previous experience..." is in fact engineering. He seeks empirical engineering, that good ol' engineering based on and verifiable by observation and/or experience rather than theory or pure logic. People have been building these building since Roman times...no need to inject higher-math into this thing...
