Anyone use OSPHO? Got tips?
MarkG
Elgin, IL
That's basically it. I bought a quart and plan to scrape, chip, and wire brush all rust everywhere I have access to underneath my truck, then powerwash and treat with Ospho when dry.
Trying to get as much life as I can out of the trusty and rusty '96 Nissan P'up.
Mike Miller
La Pine Or.
I use it quite a bit,just read and follow the directions on the container. Pay close attention to the cautions and safety warnings.
CitadelBlue
Northern VA
Good stuff. I wire wheeled under my 73 Capri and then used my spray gun OSPHO. After a few days I painted on foundation coating. That was one tough (cheap) undercoating ....
MarkG
Elgin, IL
What's the best way to handle a frame that's a combination of rust and some sort of factory coating? (I don't think it's undercoating----not sure how to tell. I bought it used) Should I still coat the whole frame, or only the areas with rust? Will it only 'cure' in the presence of rust?
Thanks.
vpd66
Central Wisconsin
If I were you I'd look into Fluid Film for vehicle rust protection. I use it on my vehicles and it has really slowed down the rust problems. It is a waxy fluid you spray the underside and inside panels (like rust proofing) of your car. You have to retreat it annually, but it seems to work good.
