Anyone use "roll material" to cover floor?
Dave5337
Buffalo, NY
I just got a magazine all about Garage Makeovers ("...from the editors of WOOD magazine...") and they had a section about flooriing, which compared and contrasted different types (epoxy, tile, VCT, Racedeck, Air Gap, Roll, etc), and I think, since my new detatched garage is being finished as we speak, that the roll material might be the ticket. They mentioned a company,
HTML:
www.bltllc.com
and so I was wondering if anyone had experience with them, or using material like theirs. Any suggestions, advice pros/cons would be greatly appreciated!
Thanks!
Newbie Dave
Wingnut65
Tampa Bay, FL
Welcome to GJ Dave.
I wonder how many of us got that magazine and have ended up here at GJ to get more info. Guilty here.
I was going to comment on how sheet flooring has similar characteristics, but that website looks pretty good. http://www.bltllc.com/blt_main.htm Their prices seem reasonable too. Website says they carry it at Sams Club and Costco too!
Hopefully someone will have some experience with G-Floor.
Jeff
mkhurley
Northern, MD
I tried the roll out floor from Sam's Club and was very unimpressed with it. Driving onto it caused it to bunch up, they dont' recommend using a jack on it, motorcycles are a definate no-no. I sent the 2 unopened rolls back to Sam's and laid down VCT.......
dmeadow
Houston, Texas
I've used this material in a couple of racecar trailers and I have a large piece in my garage as a mat over my epoxy floor. I bought the first stuff from Sam's and the second time from American Garage Flooring, a BLT distributor.
In the first trailer I used the ribbed style (no "for her pleasure" jokes, please). I found I didn't like the texture of it because it was hard to clean. You can only sweep in one direction and oily grimy bits are hard to get out of the grooves. Otherwise, it worked pretty well, though it did move around under the racecar's tires as it shifted during transport. It was the cheapest end of the range (meaning the thinnest) and had little of its own structural rigidity, which means it did move around pretty easily.
I used the coin style and the thicker type (they call it "Industrial Grade") in the second trailer. It is much easier to clean and does seem to lay down much better, but it will still move when a tire is turned on it. I used the adhesive that they sell and found that is isn't all that great. It doesn't really glue it down all that well. It just keeps it from shifting. When I installed it it was a bit wider than the trailer so I ran the excess up the walls a few inches on each side. I glued that with some adhesive that I had left over from putting vinyl baseboard in the garage. It stuck much better.
I have a fairly large leftover piece of the Industrial Grade coin flooring that I put in the garage as a work mat under the racecar when I'm working on it. The underlying epoxy floor kept chipping under the floor jack with weight on it, then oil would get to the old concrete, etc., etc. The mat prevented that. I've found it works fine under a floor jack and jackstands. It is very resistant to most chemicals and oil, though if you leave oil on it for a long time it will pucker a bit. It doesn't have the structural rigidity of some of the really thick tile stuff, but for the price it does a good job protecting your floors and it is easy to clean. I'm pleased with it in my applications. I don't think I would do a wall-to-wall application in a garage, though.
D
Dave5337
Buffalo, NY
Thanks everyone for the input. I REALLY like the VCT look so in all likelihood that's what I'll probably end up using...
Dave
