Anyone use these Hexforce wraparound wrenches?
atikovi
Suburban Washington DC
http://www.vehicleservicepros.com/product/10713473/hexforce-5-pc-wrap-around-wrench-set-no-hfk-2
I'm trying to loosen a tie rod end lock nut that is so tight that an adjustable wrench slipped and almost rounded off 2 corners. Even heated the nut with a propane torch. Thinking one of these may work better but can't find them anywhere except Ebay where I bought the last set. Seems like they are discontinued, but wonder why. Looks like a great idea when a box end wrench won't work.
manwithtools
Lebanon, TN
For tie rod lock nut, use a pipe wrench if you have too. A BIG one if needed. Just buy a replacement nut if you ****** it up too bad.
vssjim
McLean Va.
Air hammers and heat work 100 percent for me probably need a hotter torch than a propane torch
LXCam
I can't speak for that exact tool but I have a set of flare nuts ones that utilize that design that work like a champ. The steel and design looks to be identical to what I have and if it is I wouldn't hesitate to try out set
metaldad
nw indiana
looks like i need both sets from the links shown.
ez red's are smaller sizes. with overlap at 5/8 - 16mm
