AO Smith Motor spins backwards
AntonyJ1214
Hampton, VA
I have an A.0. Smith motor and it is spinning backwards. The information on the motor is it's a 1 phase motor, 230v, cat #v208 (the model with 3 capacitors not the M2 with only 2 capacitors), frame A184T, Part 355865-01-OJ. How can I go about getting it to spin the correct direction? Any help would be greatly appreciated!
A
AntonyJ1214
Hampton, VA
I cant find a schematic but this is the label plate... or is the schematic what you need at the bottom of the labe plate?
A
AntonyJ1214
Hampton, VA
I just realized that at the bottom it says to reverse change 1 and 4.... but which of them are one and 4? Are those the wires going to the capacitors or the leads coming out of the motor?
Davefr
OR
Look carefully. Usually the number is stamped on the insulation of the wires.
EOC_Jason
Bentonville, AR
Leads coming out of the motor that the power is tied to. Either the wires are marked directly or there might be small tags on them. Be sure to throw the power before opening it up...
A
AntonyJ1214
Hampton, VA
So would those be the wires going to the capacitors? It would those wires be going to something else in the motor
larry_g
oregon
Open the junction box where the wires go into the motor. You should find the lead in wires wire nutted to a bunch of wires coming out of the motor. under those wire nuts you should find 1&4. change so 1&4 are in the opposite bunch of wires, keeping all else the same. Maybe give us a GOOD picture of what is in the junction box with the wires pulled out a bit so we can see the numbers on them. You should not have to pull the cap covers.
lg
no neat sig line
A
AntonyJ1214
Hampton, VA
Went out and opened up the junction and sure enough the wires were all labeled. Switched 1 and 4 and boom... All is well! Thanks a lot for the advise!
