Appartment Garage
F
Fordrat31
Palmer, Mass
This is the compressor that I got for the shop. Its and oldie but I am hoping it will have very good preformance. It is made by Worthington and has a 7hp, 3 phase, 208V motor. I am not sure how to calculate the CFM but It should be a fair amount. The plan is to put it between the shop and the back storage area, to help reduce noise.
Anyone know how I could calculate the CFM? I know the motor rpm, and cylinder bores/stroke. Do I need any more information?
F
Fordrat31
Palmer, Mass
Just a fast update. I decided I wanted to fill the front of the building in eliminating the three loading docks. I thought it would be a good idea if I filled the area in and let it settle over the winter before I but concrete down. This should minimize any cracking. Here are some before and after pictures.
jakeb
Bay City, MI
wow....impressive space. Are you living there yet? Do you have any pictures of the transformation of the living area. I would so like to do something like this...not sure if my wife would be very interested in it tho.
jam0o0
Katy, TX
i would suggest leaving one loading dock height door. it makes it WAY easier/cheaper to have large things delivered.
Daniel Dudley
Whenever I think I'm getting tired of this place, someone like you shows up with an awesome project space.
Keep us posted.
mdbeck1
Norman, OK
I've got to agree. It's also very handy when you need to load (or unload) something from the back of a truck.
muibubbles
nj
awesome place, this is my dream to buy a factory or warehouse tpye place and convert part of it to living space....
Motofixxer
Well considering post #42 has pictures of it all filled in, I would have to say it's too late. It's a great idea and use of a building though.
KeyserSoze
Wow, awesome shop/house! I'd love to find something like that in my area.
The first part is just geometry. Displacement of a cylinder is pi*stroke*(bore/2)^2, multiply that by rpm and you get volume/minute of air going in to the compressor. You probably have bore and stroke in inches and you want volume in cubic feet, so do this:
input CFM = 3.14 * (strokeInches/12) * (boreInches/12/2)^2 * rpm
The next part I might not have quite right, but I bet it's close.
output CFM = input CFM * (input pressure)/(output pressure)
if the input is at one atmosphere that's about 15psi, and if the output is 90 psi, then your output CFM should equal input CFM divided by 6. I ran numbers for a 4" bore and 4" stroke at 1000rpm, with 90psi output, and I got 5 CFM, which sounds about right for a back-of-the-envelope calculation.
Square2.0
Very Cool. I am also 22. I just bought my first place as well. I love working on my own property. I bet your place is a blast to work on with so much space.
I do have a quick question or two if you don't mind my asking. What are you doing for work? What about does a building like yours cost to own?
