Anyone did epoxy on your basement floor? I want to do my basement first as a practice prior to my garage floor. I will be using cheaper solvent based product such as rust-oleum or quikcrete stuff in the basement as I don't need to worry about hot tire issue there and I don't have a shop down there. Just want to make it look nice and easier to clean.
In regards to the prep work, my basement floor has a thin layer of clear film(already yellowed and it looks like some type of sealer). Most of it is peeled but still need to get rid of it on several spots. What prep work would you recommend? grind the floor and power wash it?
Is acid wash needed? The only way to get water out of there is the sump pump. Will acid damage sump pump and PVC pipe?
Half wall there is painted concrete block. Can I directly apply epoxy on it? Or must I remove the paint?
