Arbour Press
D
Dustin Echoes
Gagetown , NB Canada
That's all the info I have, I'm going to get it. It will at least prevent me from using one of my vices as a press from now on. I'll post more pics if I find anything interesting about it!
dumper
Oregon
got the HF 1-ton off cl a few weeks ago for $20.. Its very handy.
dumper
Oregon
well, you are bringing up a good point. An arbor press is more convenient than a vise for pressing things, but does it provide the same amount of force as, say a 5 or 6" bench vise? I am still trying to figure that out.
D
Dustin Echoes
"Actually, $36, net of coupon . Don't know if they have HF in NB, though."
Nope, I don't think We have HF anywhere in Canada, at least I've never seen one. We do have Princess Auto, which is a similar idea. I'll pick it up, and save the abuse on the vises. I've used my Record #8 for control arm bushings, and 1 7/8" sockets for dies, it worked, but could have worked better. The right tool for the job...
Dustball
Hudson, WI
Judging from the size of the arbor press in relation to the garage door panel behind it, looks like it could be a 2 or 3 ton press.
dumper
Oregon
Your lucky, I now have something I like about Canada, I still pissed about the bacon scam (it ain't bacon, it's ham, call it ham for f_ck sake).
I thought it was "back bacon!" Hahahha
jeffk14
GA
Yeah, it's ham, no doubt about that. Stuff's purty dang good though!
D
Dustin Echoes
Well, I got it! It's heavy, but I can't find any markings on it anywhere... It's currently in the electro bath getting stripped, going to clean it up and paint it to match the shop I'm planning. The guy who had it really took care of his stuff, older guy, loads of good quality tools all over the garage. Couldn't help but notice. OCD dream! everything had it's place. Gives me a few good storage ideas. I'll post pics when it's done. Anybody know how to find out the capacity?
Larwyn
Texas
I have a one ton Harbor Freight version in my garage which sees frequent use. The next step up for me is my 20 ton hydraulic press (also HF), but it is used much less frequently.
spongerich
Monroe, NY
Using a bench vise as an arbor press is about the best and quickest way to break it and/or wear it out.
They're not designed for those sorts of clamping forces.
You know all those vises you see with bent handles, broken jaws etc?
They're owned by guys who don't have an arbor press.
D
Dustin Echoes
Cheap and easy Mod!
For those who have a press and are sick of the ram meeting your part with the handle vertical, or some other awkward angle!
I took the bottom 3 teeth off with a grinder, and now I can pull the ram all the way up, and ratchet the teeth a few notches. This allows me to have the handle at any angle I like when the ram meets my part. No more pulling 4 bolts out, turning the handle, putting them back... just to find out I needed a few more degrees. 5 minutes with a grinder, makes this tool much more handy!
Anyone out there home make a die set?
