Hobby_Man22
How do these work? Around here when it's not 100 degrees outside the hvac systems are usually oversized when it's only 60 degrees outside. It may turn on and run for only 7 minutes and shut off.
Most two stage furnaces I am aware of are about 70% on low fire. I am not aware of any that go lower.The thing to watch for on two stage is the spread in firing rate. I have seen two stage furnaces that were 100kbtu max and the low fire was 70-80k. You may as well call them single stage. If I was looking at a 100k furnace I’d want a 40-50 k low fire. It will likely run on low 90% of the time.
This is the problem with the scroll compressor .... the two speeds are not far enough apart. I'm sure they are working on the problem -- but, the design is a challenge for VS. The rotary has 25% -- with no problem.The thing to watch for on two stage is the spread in firing rate. I have seen two stage furnaces that were 100kbtu max and the low fire was 70-80k. You may as well call them single stage. If I was looking at a 100k furnace I’d want a 40-50 k low fire. It will likely run on low 90% of the time.
