Are these a good choice for shop lights
Stuart in MN
Minneapolis
It will actually take a little more than 768 watts to run the lights, but yes you can have them all on a single 15 amp circuit.
edit: You may want to consider having a couple light switches, so you can turn on the lights on one side of the garage or the other for convenience. They can still all be powered from a single circuit.
I void warranties
you also want to make sure they are residential use. ballasts for commercial use can interfere with radio wave signals. especially am radios. they say for use in either but i would make sure if you want to listen to a radio in your shop.
StaggeringGoat
Oregon
I don't think this is a problem with newer electronic ballasts. In that case you DO want commercial type fixtures that are multi voltage rated, because they are usually better quality.
Steevo
43.49600, -112.04300
My shop is 24x40 with 12 foot ceiling, and I used 17 of those fixtures. Your greater area and higher ceiling would warrant a lot more than 6 of those.
Here's mine:
djjsr
In the cornfields
Shop around a little and you can get a better price on the bulbs. I've found a couple stores that have a case of 30 bulbs for around $30.
