I started on one, if you have the space, and power and can get it cheap, they are hard to kill. However I would much rather have a good used syncrowave or the like. When the oppertuinity came for me to upgrade from a old 330A/BP to my current used syncro 250 I jumped on it, nothing but positive. Heads up if the unit is missing components such as a pedal, some of the parts can get $ and hard to track down.
All Gold Stars are 3ph so far as I'm aware.
He is probably talking about one of the older "Gold Star" machines which were in the 3x0 A/PB family of tig machines, single phase ~400amp sine wave output, AC/DC with HF. The newer Gold Star machines are indeed 3ph, but more dedicated to the stick process. Another victory of marketing.
Thanks for all of the replies, it comes with everything except a water cooler for $800. Its in very mint condition no dents or scratches just some dust. I actually want to get the older models without computer boards for the simplicity of working on them. I have a dual 50 amp breaker and run my lincoln 256 all the time without the breaker tripping or getting hot, so dose anyone know why they pull so many amps.
It's a transformer based machine with SCRS and dated, not so efficient technology. Keep in mind as with all transformer acting as a multiplier, input needed is proportional to output requested. You'd be fine for most tig work on a ~50-60amp breaker. If you plan on running all out at ~400amps, then you will need to hard wire to a 100+amp breaker.
