Are These Lights Any Good?
nvrenuf
Mobile, Al
Among other stuff, I need to buy lights for a new pole barn (no electrical installed yet). These are for sale locally, would they be worth buying?
"used 400 watt metal halide lights multi tap ballast 120v, 208v, 240v, 277v. All lights are in good working order and come with bulbs."
Norcal
How much? They are not worth a lot as a large number of HID fixtures are being replaced w/ T5 & T8 fluorescent.
Charles (in GA)
50 mi south of Atlanta
Is that a translucent polycarbonate reflector? It doesn't look quite like an aluminum reflector, hard to tell from the pic. Multi-tap transformer is a good thing.
How high will they be mounted? Height to the bottom of the reflector. If its 15 ft or more, they should work well, any lower than that, you won't like them. If Polycarbonate reflectors, that is better (to my thinking at least) since it helps eliminate "cave effect" by providing uplight that reflects off the inside of the roof, ceiling, etc.
Plan on 3 per 20 amp circuit. You could go 4 as they are 4 amp each, but that is right at the 16 amp max allowed on a 20 amp circuit.
I bought mine about 5 years ago after Wal-Mart and Sams here in ATL converted to T8's for energy efficiency and safety, and paid $40 each for 13 fixtures and got 19 bulbs to go with them. That was a bargain at the time and still is not a bad price down here for such fixtures in good condition with working bulbs.
If you plug and cord them, you really need to use 105°C cord. I got lucky on the cord as my company was throwing away a couple of hundred feet of 14 gauge yellow jacketed (rubber) 105°C cord that had a dead spot or two in it. Cord was nasty dirty and I soaked it in Tide and water (kept the ends out of the water) and scrubbed it and it came clean, and I cut 4 to 5 ft sections to wire to the fixtures. Saved me alot of money.
Certainly T8's are more energy efficient and T5's really provide the light, but for less than everyday use, and low budget, the MH still puts out alot of light.
Charles
nehog
Jaffrey, NH
Yep, price is everything for these lamps. They can be very good (I love mine!) and provide a lot of light. If they are open bottom, you must have bulbs that are protected (they have a piece that shuts off the bulb if the outer glass is broken). Otherwise should a bulb outer glass break, you have a VU radiation hazard.
In my shop I have eight T-8 fixtures per bay, and four of the HID lights (the HIDs are wired 240 volts) per bay. All bays have two switches, one for the T-8s, and one for the HIDs, so I can choose which lighting I want (usually T-8s, unless I need a lot of light.)
Price... Mine were, in the end, free. I got more than I needed (almost 60 of them) and sold the extra fixtures on Craig's list and covered the costs of my fixtures and new bulbs (and even the cost of the supplies to hook 'em up!) Most I sold for between $20 and $30 each with used as-is bulbs or no bulbs.
