Are these pliers useful or useless?
I
impactims
So I've never had them, but I see them around from time to time.
My observation is that when you squeeze down on them against a load (a hose for example) the handles and jaws seem to flex quite a bit making it impossible to apply much pressure. So, if a hose is on really tight and I use these to grip, squeeze, twist and pull on the hose, I will be very limited with the amount of grip, squeeze, twist and pull that I have to work with.
Am I the only one that has noticed this?
charbar
Midwest
Yes but that is basically the nature of the design since they are long and skinny. Even more noticeable on cheaper ones. Mine are Cornwell branded but they look like every other cheap Taiwan ones offered by other brands. They are flimsy as hell but I've never broken them and the flex I get from them has never been an issue. Generally when you are using pliers like this you are trying to use a little finesse as well instead of grabbing into something with all your might.
I use mine quite often. Hoses, certain electrical and EVAP connectors, and plug wires are probably my main uses for them.
dscheidt
you only need to squeze them hard enough so that the static friction between the pliers's jaws and the hose is equal to the force pushing or pulling. If you squeeze harder, you push the hose onto the hardline, and it's harder to move. The natural reaction is to squeeze harder, but that makes it worse, and then you squeeze hard enough to flex them. They're a finesse tool, not a brute force solution. . using a hose pick first makes it easier, but you can't always do that.
I
impactims
Never actually used them, just handled them a few times in thin air.
So, it only takes a minimal amount of clamping force for them to work effectively thus the tendency to flex under load is a non issue?
FigN⋅m
Correct.
It's unlikely you will clamp down and just simply pull hard in-line with the fitting.
Usually you will gently(ish) rotate the hose as you are pulling it away.
As stated, they work well in conjunction with a good selection of picks
Newell33
Midwest
I love these pliers, but I wish I could find a smaller set that works on ATV / motorcycle fuel lines. Typically, the smallest pliers in the sets of 3 are just a bit too big for these lines. Has anyone found a mini pair that works on the thinner OD 1/8", 3/16", and 1/4" fuel lines?
Rusted Nut
PNW
Get a couple thinner pieces of rubber or even tape, wrap around hose and then use pliers.
Fedwrench
Valley of the sun
Both. Depending on what you work on, they can be quite useful. Some of the cheaper versions have such poor jaw alignment that they can be difficult to use. I'd recommend getting at least a couple of common sizes. For larger hoses there are slip joint versions available with thicker jaws from a bunch of brands. :beer:
LXCam
Your needle seems to be stuck on the handle flexing. Yes they flex, but not as much as the hose you’re removing. So handle 1, hose zero.
Bud these things are great for their intended use. I have two complete sets in different lengths, I luv’m.
JradM
Alberta
It shouldn't matter. You don't need a lot of pressure for them to work.
There was another thread about this, maybe a year ago, where people debated different brands, styles, teeth, etc. The thing is, you're gripping hose.
Hardened teeth, stiff steel, leverage... it doesn't matter much. Pliers made from mild steel would probably work, provided they didn't bend and stay bent when you squeezed. Hose is much softer than steel.
I have a cheap 3pc set of these - they work great for their intended purpose. You don't want to crush the hose or cut it. I use them to grab the hose at the fitting, twist to break it free, then grab below the barb to remove.
^ NO idea who made those in that photo - it's too fuzzy.
Mine were made by Proamerica. They private-label them for a number of other companies.
MR2FC
I bought some cheapies, never used them but they looked interesting...
...my other half thought they were some kind of implement of torture, and gave me a funny look when they were delivered
Banjorear
Essex Co., NJ
I agree. You don't want them to be crushers; especially when dealing with plastic barbs or other delicate hook ups.
andys
Bucks County, PA
I have them and use them weekly for hoses, plastic tubes, spark plugs and some electrical connectors.
They are not for brute force, but for applying pinching power where you fingers can't or won't get it done.
dscheidt
It's telling that Knipex do not make a version, and the only version of these Snap-On have in their catalog are chinese imports.
CoogarXR
I have the old orange-handled harbor freight set. They work just fine for me. They are nice for spark plug boots and heater core hoses. That's what I use them the most for.
hobie18
I can't tell you how many hours, nor how much frustration these have saved.*
You need to put as little pressure as possible. Most barbs and tubes are easy to damage. Heater core could be ripped, gouged, or slightly scored. Any would end your day, and add a few more.
*mostly cause I can't find them. 😄
snickers muncher
Northeast GA
I've got a cheap set from HF. As mentioned they're great for pulling hoses, spark plug wires, and some electrical connections if you're really, really careful. Also great for removing and installing large horseshoe shaped C clips like on axle bearings.
Sbusmech
Texas
I use them every now and then. Great for holding hoses in place in limited access places. Like any specialty tool, you don't always need it, but when you do...
johninct
I have never seen these, dumb question, do you grip a hose with the tips or the circle part?
