Armorclad Military Topcoat question
jtcz28
C-bus Ohio
Hello everyone!
Purchased the Armorclad kit (thanks Armorclad for the discount!!) and had a question on the Military Topcoat.
Wanted to know if I should do 1 coat or 2 and if you placed the anti slip agent in both coats or just the last coat?
Just finished the acid etch on our newer garage floor and had to buy more. Did not like the amount of etch the first coat did // user error due to time and cops being called (guess power washer at 9-10 at night bothered someone).
Going to be putting down the epoxy tonight then once dry then Military Topcoat.
Thanks!!
Armorpoxy
We normally include enough to do a single coat. If you are planning on doing a second coat, and have enough material, then the non skid gets mixed into the final coat that you walk on.
Thank you.
J
jtcz28
C-bus Ohio
So base epoxy went down with no problem and dried over night. Let sit 24 hours and looked awesome. Put the military top coat down Thursday night and it is still wet...... Not sure what went wrong as I mixed it 2:1 as noted and added the anti slip in with required mixture. Any help or advice to fix issue would be great. Only thing I can think of was that I did not use a power mixer rather a paint stick to stir up the top coat. Bummed......
