Armorpoxy ordered today!
dillont
Southeastern CT
Been a long time lurker, made my order for armorpoxy today. Should be delivered before the weekend. I am going to be power washing the floor, etching and then coating it. Went with medium gray and red white and blue flakes.
24x24 detached garage with minimal staining. Ill update this thread with more info as I get it.
D
dillont
Southeastern CT
Thanks. What is square footage and price? Really looking forward to following your progress.
the garage is a little over 500 sq ft. I ordered the 600 sq ft kit, and I got a can of prime to go over the few oil spots if I cant get them out.
armorpoxy offers 40% off to forum members, so I payed a little less than $400 shipped. I ordered yesterday and it is arriving today.
CaneDawg
Dang, 40% - I might be ordering soon. I just started scraping the popcorn ceiling, have a few Saturdays to go before I get to the floor.
D
dillont
Southeastern CT
The kit came in yesterday! 1 day shipping lol. This weekend I will be powerwashing and then acid etching.
ford fanatic
Darlington, Md
Nice!
I just finished painting my new 3 car garage, I will be ordering my kit from Armorpoxy in the next week or so. Good luck, keep us posted.
Marcm157
Newburgh, NY
I didn't realize the discount was so substantial. I may have to jump on this before they pull that deal...
bry@n
Ocean County, NJ
Can't wait to see the finished product. really considering doing epoxy in my basement. I think it would look great and save me a ton of money over tile etc...
D
dillont
Southeastern CT
So I ran into some issues... Got the garage all cleaned out. Power washed it with cement cleaner to prep for the acid etch. I realized there's some water seeping in around the cinder block foundation. this will have to be tackled before coating the floor...
Suprman
can't wait to see the red/white/blue on the gray. how do you get the 40%off? i was going to do rustoleum kit, but this might be a better deal in the long run.
D
dillont
Southeastern CT
I sent armorpoxy an email and then called to order. I was in the same boat, this is just a 10x better kit than rustoleum, especially with the size of my garage. Ill be posting more pics, working on a waterproofing solution now.
Thinking hydraulic cement on the outside with a coat of drylock paint on the cinderblocks. let the blocks dry out and then paint the inside. Also have new seals coming in this week for the garage doors.
doctorsouse
Northeastern CT
Good luck with the waterproofing. Looking forward to the results as I have decided to wait to afford a better product than the big box store brands.
D
dillont
Southeastern CT
so last night i used some drylock and did the outside of the cinderblocks, and emptied the garage out. acid etching tonight and then putting down the epoxy after work tomorrow
Suprman
Following along even though i'm technically ahead of you(acid etched once, will need to do it again after grinding some spots). been stuck moving, so you will pass me here soon.
Trey T
Houston, TX
You might want to consider no flake at all and just throw down (up actually) alum. oxide additive for traction instead.
I think single color is a better look, classy, and timeless. Also, when working on cars and stuff, it's a lot better to work on a uniform color floor than flaked flooring. Many professional shops, particularly high-end shop like Porsche, stick w/ bright single-color floor. When I think about flakes, I think it's contractor grade on new homes around here.
Something to consider.
D
dillont
Southeastern CT
im hoping a one time etch will be enough. I scraped some weird rust off the floor, going to give it a once over before etching. then prime the spots that look a little oily.
while you bring up a valid point, this isnt any sort of commercial shop or anything. I think ill be happy with the flake.
Suprman
Yeah once should be good, i just missed some spots and didnt grind some spots before like i should have. I got a 4.5" dimabrush and scrapper now and can do the couple tough spots before i acid etch again
Sent from my Nexus 5X using Tapatalk
D
dillont
Southeastern CT
acid etch done, hopefully epoxy starts tonight
jtcz28
C-bus Ohio
Do you have a black top driveway leading up to the garage? Hard to tell if the one image you sent shows this due to my browser. If so did the Acid etch any of it? Thanks!!
D
dillont
Southeastern CT
yes i do. not sure if the acid etch did anything yet. right now there's just cement powder/residue stuck on the driveway. waiting to finish the epoxy before I try and power wash it away. want to minimize possibility of water getting on the cement floor.
D
dillont
Southeastern CT
got the primer down. emailed armorpoxy about it. kind of concerned with what happened
D
dillont
Southeastern CT
sorry, dont really check this on weekends. they ended up saying everything was a go. I put the epoxy and flakes down then clear coated saturday. came out great.
Suprman
Nice! Any tips/tricks? I think ill have time this weekend to start laying it down.
D
dillont
Southeastern CT
you 100% need a friend to help. I didnt do this, but in hindsight I would have done some more math and figured out a system to actually ration the coating for the whole floor. I put it down pretty thin at first and had some more leftover than I expected.
other than that, nothing crazy. keep everything clean, wear your mask, and work quickly.
also if youve got some leftover pull your roller out asap or it will harden into there fast. ask me how I know.
Suprman
Sounds good, ill make the GF help
