Armorpoxy White Metallic Project
Armorpoxy
Hi All,
Thought we would share an installation of an unusual metallic floor.
Customer wanted white floor with bronze metallic veins. We topcoated with a satin sheen topcoat.
This floor is our Armorultra in white with Bronze metallic. We wouldn't recommend this for a garage floor since being white epoxy it could yellow in the sun but in a basement it should be fine especially since we used UV blocking topcoat.
Hivolts
Beautiful.. Is there a good choice for any type of white epoxy in garage? I was planning on white until reading the above.
Thanks
A
Armorpoxy
Sure you can do white but it needs white pigmented topcoat. We don’t suggest metallic look since the white topcoat is not epoxy to muddle with the metallic. If you do a fleck white floor you need an extra coat as you have to broadcast onto white topcoat instead of epoxy and then clear coat.
Last comment is white is very hard to keep clean from tire marks and debris so we don’t like to recommend white in a garage, better to use light gray for a light floor.
