Armstrong Socket Without Square Ratchet Drive Opening
MadeinCanada
Thunder Bay, Ontario
I have two sockets with 1/2" through holes where the square ratchet drive opening would be located. You turn the sockets with a 3/4" wrench. One is a MD-12433 (longer one) and the other is MD-12362 (shorter one). The MD-12433 appears to have the end turned down for approximately 1 1/4". Probably owner modified but possibly factory. Can anyone identify what these were used for?
JjKk40
New York
Those look like specialty sockets, similar to antenna sockets or sockets that have to get down deep over a long stud and you use a wrench to turn it.
bmwrd0
Beaver Fever Oregon
Some specialty use, looks like a deep nut with some secondary adjustment. So, you could turn a nut while at the same time adjust a screw through the top.
M
MadeinCanada
I agree that they are some sort of specialty socket. It is interesting that they have the same hole diameter and both use 3/4" wrench to turn them although the longer one is 9/16" and the shorter is 3/4". I would have thought the sockets would be scaled up proportionally. Well made sockets and will reside with the orphan collection waiting for the day they are needed.
M
MadeinCanada
Interesting idea if made for McDonnell Douglas. I am not sure if MD had a plant in Canada although I only live 40 minutes from the Minnessota border. I have on a few occasion brought used tools home from the US when traveling.
