Armstrong tool boxes
lincwelder225
Somewhere out there
PureLeaf
Never used or seen an Armstrong box in person. Proto also does nice USA boxes.
Cripe has had that box forever trying to unload it.
6PTsocket
I don't know how much of a consideration it is for you but Armstrong no longer exists. It was shut down by it's parent company, Apex. If you ever need a part that might be a problem.
L
lincwelder225
Somewhere out there
PureLeaf- I know they've had it awhile... I've been looking at it for some time. Wonder if they would negotiate on the price?
6PTsocket- I was aware that they were going out... Sad actually. I did think about getting slides, casters etc for it down the road if and when it is needed. I wonder if another make/brand would be compatible. I heard that the Armstrong boxes are made where the Matco ones are... Thanks for the heads up!
bobcatdan
Kaukauna,WI
No these are different matco only makes tool boxes
To Armstrong boxes look good but you will have issues replacing slides years to come
The big Armstrong boxes are older matco designes that were made in the same plant as matco boxes from when both companies were under the same ownership. Up until the new revel boxes, minus visual tweaks, matco boxes really hadn't changed in 20 years.Any Armstrong box for sale now is NOS. Proto and mac boxes are basically the same as well.
6PTsocket
Matco is owned by Fortive. It was sold off by Danaher. Danaher also owned Armstrong that eventually ended up as part of Apex. My point is that they started out as divisions of the same company and the box was probably made by one division to supply another. If Apex has no parts, I would guess Matco won't either. I could be very wrong.
bobcatdan
Kaukauna,WI
I would think the slides are fairly common, brand name accu-ride slides and if the need for replacement ever came up would probably easy to source.
L
lincwelder225
Somewhere out there
To bobcatdan and anyone else-
You seem to know a bit about toolboxes, I don't know much about their construction. Can you or someone translate this into layman terms or tell me what the construction is, compared to something like a snap on vs craftsman box? Here's what their website says:
Made in the USA - Quality and Availability
Industrial Series is Designed for the Heaviest Industrial Use / Largest Capacity
Unibody Design Maintains Squareness and Allows for Extra Load Strength
Double Wall Construction with internal “L” Channels for Increased Drawer Support
Weight Bearing Corner Post Design with “U” Beam Floor Panel for increased Rigidity
Scratch Resistant, Durable Powder Coat Finish
6" X 2" Casters for a Load Rating of 3,600 lb. per Cabinet
Full Extension 75 lb. Rated Ball Bearing Slides
Double Slides on Selected drawers
Includes Drawer Liners with a Thick Rubber Top Mat
SuperCat
Sacramento, CA
That looks like a great box, however I have a question:
How can they describe that as "Designed for Heaviest Industrial Use" when the slides are only rated to 75 lb.?
Even the much cheaper $1000 Home Depot Husky brand 56" combo box set has 100 lb. full extension slides.
http://www.homedepot.com/p/Husky-56...t-Textured-Black-Matte-HOTC5623BB1S/206842294
I am not recommending the Husky box because I don't have one, I just wanted to make a comparison of the slides.
(Also, the Armstrong box is much larger, it is longer at ~74" and deeper at ~25", versus the Husky combo box set at 56" by 20" deep. The Armstrong box total weight capacity is 3600 lbs. versus Husky combo set at 2500 lbs.)
Hope this helps, did not want to derail the thread with a discussion of another brand of toolbox. :thumbup:
WittHay
Surrey, BC Canada
What I do is compare 2 or 3 tool boxes of the same dimensions. Check how much each box weighs. Heavier box, more metal should be stronger. Then the drawer configuration, will it work for your tool collection Then how are the drawer pulls, entirely personal, doesn't matter how well the box is built, if you hate pulling on stiff drawer detentes, you will get tired of it
The boxes listed below are around 73 x 25 the common size is 73 x 30
The US made Armstrong 16-790 weighs 820 lbs
The Canada made International SRB-7321 weighs 770 lbs
The US made Proto J557843-20 weighs 875 lbs
The Harbor Freight US General 72" box weighs 528 lbs
L
lincwelder225
Somewhere out there
Genius!:bowdown: As to feeling how the drawers slide, I'm gonna buy this without actually seeing it in person.. I know, taking a big risk and all that. Hence my post.. Checking the box weight is an excellent idea! I should call Apex/Armstrong and see if they can tell me what gauge steel that the box/drawers are made from. Thanks again!
L
lincwelder225
Somewhere out there
Went ahead and ordered the bottom box... I have to call tomorrow and approve the shipping.... I'm super stoked and can't wait to get it! Thanks to everyone for their advice and help!
