I just noticed that my vintage 2hp/12 gal Sears compressor came in two versions - one with an ASME tank and one with a regular tank. Both have 100 psig cut-off pressure but they have different safety valves. I have the regular tank. I discovered this because I cranked mine up to 125 psi and was surprised that the safety valve held. It is working fine so I know it is not stuck. The parts list does not specify the safety valve set point. Does anyone know how much pressure these tanks can safely handle? The obvious answer is 100psig but I suspect the ASME tank is designed for considerably more than that. Also, I suspect the regular tank is exactly the same except Sears did not pay for the ASME stamp. Thanks.
